New Warn VR vs M8000 - JeepForum.com
post #1 of 65 Old 04-19-2011, 07:26 AM Thread Starter
nufga
2010 JK Wrangler
After yesterday's announcement, I feel like I have to completely rethink my originally plan for a winch purchase. I was dead set on getting the Warn M8000 on Friday, but happened to be too busy to order it. I knew I wanted a Warn and the M8000 was really the only thing in my budget.
Now that the VR Series has been introduced I have a few more options. The M8000 is still lighter weight and faster than the VR8000, but also about $100 more (after including the mount, etc.) Should I take the savings? Can anyone shed any light on why I might want one over the other?
Also, I find myself considering the extra power from the VR10,000 now that it's at a comparable price point to the M8,000. I was already planning on paying the $539 for the M8,000, should I just skip the VR8,000 and go ahead and get the VR10,000 for $500 (after rebate)?
Any help is appreciated. I've been in the market for a winch for a long time and think my patience has paid off. Now I just need to make a decision.
Thanks for any help.
nufga is offline
post #2 of 65 Old 04-19-2011, 08:06 AM
BigMikeATL
2014 JK Wrangler
I just got my M8000 last week. Time will tell if the VR series will hold up time and time again. I got the M8000 because it is a tried and true winch and I want to know that when I need it, it is going to work. The VR series might be just as good. I think Warn had to do something to compete with all of the Chinese winches like Smittybuilt and the like.
2014 2D Rubicon, 2.5" Metal Cloak Game Changer ARB, ProComp 7069 17x9, Goodyear MTR Kevlar 35's, ACE Pro Series Bumpers, Warn M8000
2011 Grand Cherokee Overland HEMI MyGig Tow Pkg
2009 2D Rubicon SOLD
BigMikeATL is offline
post #3 of 65 Old 04-19-2011, 08:09 AM
rcking323
not sure if you have seen this yet but....http://www.cabelas.com/product/Warn-...h-All+Products
rcking323 is offline
post #4 of 65 Old 04-19-2011, 08:26 AM
Mol
Disclaimer: I'm Polish
Mol's Avatar
I am curious about the VR - anyone have a link or pic to a chart of the differences in line speed, HP, spool size, etc. of Warns different winches? A Warn at the cost of a rugged ridge or smittybilt is attractive, but I'm curious at what sacrifice this low cost, costs...if you will
Mol is offline
post #5 of 65 Old 04-19-2011, 09:41 AM
BigMikeATL
2014 JK Wrangler
I emailed them this morning to ask the difference between and M8000 and a VR8000.
Looking at the specs, the line speed is slower for the VR under a load. Interested to hear Warn's response.
post #6 of 65 Old 04-19-2011, 10:20 AM Thread Starter
nufga
2010 JK Wrangler
Thanks for the input. BigMikeATL, I had the same thoughts about the M8000 being a proven winch. However, Warn is also a proven name, so I hope the same quality is included.
http://www.quadratec.com/products/pr...&pn=92136.010X
If you go into product detail for each one, it breaks down the speed at different loads. I've not owned a winch before, so I'm unsure of how much of a preference factor the speed is as long as it's reliable and gets the job done.
Anybody have any thoughts about a Warn 8000 vs a 10000, in general, at those prices?
nufga is offline
post #7 of 65 Old 04-19-2011, 11:25 AM
Mol
Mol's Avatar
My thoughts exactly...if I can buy a Warn 10Klbs at the same price as a Rugged Ridge 10Klbs...the name and inherent quality associated with that name, seems to make the Warn a no brainer. I'll do some further reading into spec comparisons
Mol is offline
post #8 of 65 Old 04-19-2011, 12:12 PM
Mol
Mol's Avatar
I got tired and haven't yet added in the smittybilt or any other comparable, money saver, base model winches. I'll be happy to add to the chart at your request Mike
Mol is offline
post #9 of 65 Old 04-19-2011, 12:55 PM
nwbronco
2014 JK Wrangler
In self recovery mode, any of the winches will suffice. You get stuck, pull out the line, and winch yoursef out. Line speed is what it is. You'll get out faster with the faster line speed. The amount of cable on the drum is the pull speed/load determiner.
Constant duty, being at the lead and have to turn around and winch your buddies up a bad spot, here's where the stuff can hit the fan. Or, a trail that the winch line is out for extended periods. Inferior winches will heat up and stop. I've seen other winches have to pause, and I've seen not so well maintained Warns fail. You see the minimum battery requirements listed. I'd say that's not even close. Get the spec sheet for all of them and look at the load draw under full pull. That'd be as important in the winch game, power leads, too.
First pass, looks like the VR is put together a little cheaper, and it only says 12VDC motor, doesn't mention the motor size, which is okay if the same motor and relays are used as the M series. Then you just need to maintain the VR so it doesn't rust if it gets scratched.
Bob K.
His 14 Anvil JKUR-X
Hers 09 Blue JK
Kid's '08 Yellow JKU
'13 Black 10A Rubicon JKU
nwbronco is offline
post #10 of 65 Old 04-19-2011, 01:09 PM
BigMikeATL
2014 JK Wrangler
THE OFFICIAL WORD
Just got an email from Warn. Copy and pasted below:
The main differences between the current M8000 and the VR8000 are:
  • They use a different motor.
  • They utilize a different gear-train configuration.
  • They have different hand-held remotes.
  • The VR8000 uses solenoids in the control pack and the current M8000 uses a contactor.
post #11 of 65 Old 04-19-2011, 08:42 PM
saharacon87
Originally Posted by BigMikeATL View Post
THE OFFICIAL WORD
So in other words I should save my pennies and go for the M8000...?
TJ 3" FT, Front Currie Arms, v8 zj steering, 30 locked/44 open, 33 m/t, Armor
saharacon87 is offline
post #12 of 65 Old 04-19-2011, 11:29 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
Different motor - big deal.
Different gear train - planetary gears and quality big deal to me.
Control difference, who cares if it works.
Contractors vs solenoids? Bull$hit if you ask me, same thing. Surprised Warn would pull that crap on valued users?
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #13 of 65 Old 04-20-2011, 06:15 AM
Apocalypse
Real question to me is is the M8000 $60 price difference worth it. As stated above, the M8000 is proven and if there's some ambiguity over possible cheaper parts/design in the VR8000 then I'll go for the proven one for a pretty insignificant price difference.
08 JK lots to do...
IndyORV
Apocalypse is offline
post #14 of 65 Old 04-20-2011, 07:48 AM Thread Starter
nufga
2010 JK Wrangler
RockyClymer, not sure if I'm getting your message across right- are you saying that the differences aren't material enough to warrant paying the extra $140 (rebate) for the M8000?
nufga is offline
post #15 of 65 Old 04-20-2011, 07:53 AM
Captainak
1982 CJ7
Molshove,
I love to see the chart with the Warn PowerPlant 9500..... where do I get the chart?
Sent from the iPhone, "82" CJ7 Built Not Bought, Captain, USA (RET)
1982 CJ7, AMC 401, Dana 60 & 14 Bolt
http://jeepspace.jeepforum.com/Captainak
https://plus.google.com/photos/116451153412037001676/albums/5857883655447386049
Captainak is offline
Warn M8000 Tradewinds TJ Wrangler Technical Forum 2 11-18-2010 01:49 AM
set up of warn m8000 GRN_BEAST95 YJ Wrangler Technical Forum 10 02-01-2009 07:42 PM
For those who have a Warn M8000 JK Gator JK Wrangler Technical Forum 14 01-21-2009 08:17 PM
Those with a Warn M8000..... Hunter9 TJ Wrangler Technical Forum 8 04-10-2006 01:42 PM
Warn M8000 TellyDSP YJ Wrangler Technical Forum 1 04-24-2003 01:37 PM
