New to Jeeps looking for answers
| Great deals on Mickey Thompson Tires @ Jeephut.com | RCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com | Poison Spyder Brawler Rockers! |
#1 | |
Hi guys,
My name is Steve and I am from Michigan. I am looking for opinions on what jeep to purchase. My wife and I intend on using it for trail riding, street running and bolting on a set of paddle tires for use at Silver Lake Sand Dunes. I would like to have a V8 or convert to a Chevy V8. I am also thinking of a tire size of 35's. The problem I am having is what to buy as a base rig. A CJ 5 or 7 or a newer Wrangler. I am not sure what all the differences are as I am just starting to look into this project. I would like to buy yet this fall so that I have all winter to work on it. Any thoughts? Thanks Steve
#2 | |
My uncle has a cj-7 that he uses for uphill drag races that has a 383 stroker in it. I think you'd have better luck with a cj. hth
Mine: 1998 TJ SOLD...but not forgotten. Hers: 1981 CJ-7 Under Construction. |
#3 |
I love my Cherokee. Had a ball in Silver Lake. We love it
01 XJ/4" lift/33" DC Muds/Sidebiter Wheels/Surco/ Hi-lift/Pilot lights/Bad Apple Fab diff gaurds/Front and rear receiver hitches/Rusty's LCA's/ Magnaflow/Rubi HD Track bar and Brace/Big Daddy tie rod/TB Spacer/Ractive air intake/ Jet Stage 1/Pioneeer & Fusion Sound/AJ's Super rails/Warn Skid /BW Flat Flares/Bedlined Rockers and Quarters |
#4 |
I don't have much exp in sand but from what I have seen usually sand is higher speed. I would tink a longer wheel base would be better.
2001 TJ, 33 trxus MTs , red W on the front bumper, locked and more "If you aim at nothing, you will hit it every time." — Zig Ziglar |
#5 |
Longer wheelbase..............V8............. get a ZJ!
#6 |
CJ's can be found with V8's, but you'll be hard pressed to find a newer the YJ (87-95) or a TJ (97-) with a V8. The strongest stock engine the TJ comes with is a 4.0L I6, definitely capable enough for any off roading you'd be doing. If you wanted a TJ with a V8, you'd have to do it yourself or find one used that had a V8 dropped in by the previous owner. CJ's and YJ's have leaf spring suspensions, and the TJ has coilspring, giving it a smoother ride, and from what I can tell, better wheel articulation as well. Any of those three are a great choice though, very easily modifiable and rugged enough to take anything you throw at them. Good luck with your decision!!
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
