New jeep owner looking for tips and hints - JeepForum.com
post #1 of 4 Old 08-02-2012, 06:08 PM Thread Starter
Kionomics
I recently purchased a 2012 wrangler and absolutely love it. Just looking for some tips from some veteran jeepers or anyone with some words of wisdom. I am definitely a jeep owner for life. I live on 80 acres of forest playground!
Kionomics is offline
post #2 of 4 Old 08-02-2012, 07:34 PM
BlueRubiconrich
you need protection: oil pan,diffs etc.
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
post #3 of 4 Old 08-02-2012, 09:38 PM
NonRubicon
Armor is nice to have, but you need off-road wits too.
  • Always safety check your vehicle before heading out on the trail. Even new vehicles can break down.
  • Whenever possible, don't wheel alone - a second vehicle is always preferred especially when in more remote areas.
  • Always leave an itinerary (your planned route and return time) with someone you trust; don't rely solely on a cell phone to have coverage to get you out of a jam. Be prepared to hoof it out or wait for help if you're alone.
  • Carry recovery gear - basic tools, spare fuses, recovery strap, shovel, first aid, fire extinguisher.
  • Make sure your spare is good, and aired up - have a usable jack.
  • If you aren't sure how deep a water crossing is, get out and walk across it first.
  • If you aren't sure what's over a ridge you are about to crest, get out and check.
  • Be cautious when you cannot clearly see the ground in front of you - rocks, debris or crevices could be hiding under vegetation.
  • Don't make a u-turn on a steep slope - drive directly up/down.
  • Air down tires for a softer ride off road - be sure you have a portable air source to refill them before getting back on the road.
  • 4WD isn't true 4WD unless you have lockers.
Probably lots of other things I can't think of right now.
NonRubicon is offline
post #4 of 4 Old 08-04-2012, 09:05 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Here's a tip: beware the pentastar, it goes through belts like Rosie O'Donnell.
And again
Luck Favours The Prepared
Anticanman is offline
2012 , wrangler
Jeep Tips - Thanks for your help too! jeepers1 General Jeep & Off-Road Equipment 3 02-13-2012 10:05 PM
Just got first jeep, Any tips,tricks i should know Skytard Cheap Tricks & Fixes 35 04-26-2011 01:03 PM
Hints for MIG welding upside-down? Jerry Bransford Fabrication Shop 26 09-22-2010 09:23 PM
232 Hints, Tips, ect. Psyker Engines & Drivetrain 1 08-27-2009 12:08 AM
Hints on removing c-clips from locker beachtaco General Jeep & Off-Road Equipment 2 04-27-2005 11:30 AM
