Need a vendors help...Need help shopping for leaf spring bushings! - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > General Jeep & Off-Road Equipment > Need a vendors help...Need help shopping for leaf spring bushings!
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! April Instant Rebate: Up to $75 off Flowmaster Products!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 04-12-2015, 02:57 AM   #1
chainz
1976 CJ5
Hello, I am trying to replace all of my bushings for my leaves to include spring eyes and shackles and am having trouble finding the correct ones to where there is no duplication in the packages; i.e. I have YJ springs in the back of my jeep and the original CJ springs in the front and I am having trouble finding/putting together the right amount of bushings that I need. Is there a vendor on here that can help me out maybe? Or can someone else help me?
chainz is offline   Reply With Quote Quick reply to this message
Unread 04-12-2015, 07:57 AM   #2
JeeperDon
JeeperDon's Avatar
I can't help with your exact answer, with part numbers and all, but I know when I did my YJ I had to buy two or three different packages because there was no perfect kit with all 12 bolts worth of bushings exactly the right size. I decided to go with Energy Suspension, so went to their site to look at bushing sizes and packages. I was able to almost get there. I ended up with two bolts worth (4 pieces) of the small size upper shackle bushings on the shelf. I've since used two of those pieces for other non-suspension things.
'93 YJ, '02 GM 4.3 Vortec V6, SOA, dual ARB's, 8.8+D30(w/WarnHubs), 4.88 gears, 35" BFG KM2's, AX15, 15x7 wheels, NP231+4:1+SYE+2LO, York OBA, Warn M8000, no top or doors Apr-Oct.
Member and Web guy: New Mexico 4 Wheelers My Truck Page on NM4W Site
JeeperDon is offline   Reply With Quote Quick reply to this message
Unread 04-12-2015, 09:11 AM   #3
chainz
1976 CJ5
Yea I think that is what I need is the small bushings for the frame side of the shackle and a larger one for my spring side of the shackle and the websites are confusing almost seems like I don't know what I am buying.
