Need help identifying this object in jeep - JeepForum.com
post #1 of 7 Old 04-06-2015, 04:50 PM Thread Starter
TJaefick
Just bought a new jeep and this is bolted to the bottom of the driver side area under the steering wheel. It looks to be wired into something else that has a small dial with "min - max" on it. I'm thinking an alarm system, but what is this thing in the first picture. it has no buttons, switches, or anything.
thanks!
'05 LJ, 2" OME, ARB/4.56, 33x12.5
TJaefick is offline
post #2 of 7 Old 04-06-2015, 08:11 PM
Mousejockey
Thinking alarm also, dial may be for sensitivity setting?
Check the wires it ties into against the FSM
Mousejockey is offline
post #3 of 7 Old 04-06-2015, 09:57 PM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
That relay doesn't look factory either.
***Chris***
chris87xj is offline
post #4 of 7 Old 04-11-2015, 05:30 PM
PhulesAu
After market amp & Sub? gain control for Amp?
PhulesAu is offline
post #5 of 7 Old 04-11-2015, 08:10 PM
dwilliams35
I'm thinking glass break sensor for an alarm.
dwilliams35 is offline
post #6 of 7 Old 04-13-2015, 11:37 AM Thread Starter
TJaefick
I traced everything over the weekend and it's definitely an installed alarm system. When I started unplugging everything, the jeep would no longer start due to an ignition interlock. I'm guessing the small device in the front is a valet override or something.
TJaefick is offline
post #7 of 7 Old 04-13-2015, 03:30 PM
dirtdudeaz
1983 CJ7
Depending on the type of system you have, a lot of the brands use the flashing red light as a valet button.
That looks like a glass sensor (or maybe a shock sensor) as someone else mentioned, and it's attached to the system sensitivity control. Pretty standard stuff.
dirtdudeaz is offline
