need to find winch remote - somewhere between Ohio and Moab on I70 - JeepForum.com
post #1 of 8 Old 04-11-2014, 01:52 PM Thread Starter
ldso
Yeah, I'm leaving Ohio in the morning and towing the YJ to Moab. Last night I was loading the Jeep, and I can't find my winch remote anywhere. Called a shop in town, but they didn't have anything. It's a Road Shock Harbor Freight winch. The usual 3 prong connector on the solenoid box.
I'm sure there will be many winches on the trail, but if anybody knows of a place that sells recovery gear close to I70 between Columbus Ohio and Moab let me know! If you are there in person I will give you a cold Heineken.
1995 YJ "Mabel", 2.5L Muncie SM465 np231j 4.88's HP30 Lockright JK 44 Detroit 33s CJ clip
Actually, it's pronounced "mill-e-wah-que" which is Algonquin for "the good land."
ldso is offline
post #2 of 8 Old 04-12-2014, 12:36 PM
athos76
If you are in a bind, stop by a hardware store and get a spdt switch and some wire and make one. Just wire the switch to the connector with some spade terminals, and it should work fine
2006 I6 6-Speed X, 33" Goodyear Duratrac, 8.8.
athos76 is offline
post #3 of 8 Old 04-12-2014, 07:43 PM
wilson1010
I assume the remote is the female end of things, like it is on my MM.
You can activate the winch with a nice wide screw driver or a chisel. Connect A and B it spools forward. A and C and it goes back. Of course, I am just making up the AB&C. You will have to experiment with it. Don't get your necktie caught in it while you are bending over to activate it. I assume you will be dressing for Moab?
03 Rubicon; 99 xj with too much stuff to list; Unimog 406 (gone)
wilson1010 is offline
post #4 of 8 Old 04-13-2014, 08:50 AM
Oldjeepman
does harbor freight stock them? Should be one in Denver. There is a 4wd Hardware store in Denver also,plus lots of off road shops..if your going to be in Denver.
Oldjeepman is offline
post #5 of 8 Old 04-13-2014, 08:57 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Get a momentary on/off/momentary on switch and some wire to emulate this one
http://www.jeepforum.com/forum/f46/7...72/?highlight=
Luck Favours The Prepared
Anticanman is offline
post #6 of 8 Old 04-14-2014, 10:04 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
Rather than ask here for a place, call Warn and fine a dealer along your route.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #7 of 8 Old 04-21-2014, 03:13 PM Thread Starter
ldso
Thanks for all of the helpful tips guys! I am back from Moab, I didn't need the winch The speedo quit on my truck so I will fix that and then figure out the winch remote issue.
Thanks again!
BTW I did pass through Denver, after being in the craziest ice storm I've ever seen! Semis jacknifed everywhere, pickup trucks flipped etc.
ldso is offline
post #8 of 8 Old 04-21-2014, 05:12 PM
wilson1010
If that was Easter Jeep Safari, how bout some photos?
