Quantcast MY poor man's paint job and herculiner - Page 5 - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > General Jeep & Off-Road Equipment > MY poor man's paint job and herculiner
Old 05-30-2008, 02:30 PM   #61
Mr_McNasty
Okay since this is so enticing for me and yours turned out so damn nice, I have a couple of questions for you.
What exactly were the supplies you bought, the amount of the item (paint, rollers etc), and the price you spent?
How much time did this all take? (From parking it in the garage and preparing, to reinstalling the painted parts)
1998 Wrangler
O|||||O
4" Rough Country X, 33" Mud King XT, Custom Quick Discos, D35 Lockright, Stock front bumper (Chopped to shorty)..
Originally Posted by billyjp2 View Post
i burnout on puppies and kittens
Last edited by Mr_McNasty; 05-30-2008 at 02:36 PM.. Reason: Had more questions to ask!
Mr_McNasty is offline   Reply With Quote
Old 05-30-2008, 10:32 PM   #62
Executioner
1965 CJ5
I spray bombed my dark green CJ5 the brightest Krylon yellow I could find and after wet sanding it ended up like a mirror
Before I owned a 65' jeep I didn't understand the term "It's a jeep thing"
After my first ride top and doorless...I think I understand. And don't care how long the line or cars behind me is due to my innability to maintain 55mph.
They all need to slow down anyway.
Executioner is offline   Reply With Quote
Old 05-30-2008, 11:00 PM   #63
choeyreplied
very nice blue jeep
choeyreplied is offline   Reply With Quote
Old 05-30-2008, 11:12 PM   #64
HeepToJeep
1982 CJ8
Originally Posted by Indy View Post
I don't think an auto paint store would even mess with mixing rustoleum.
No, no.....I mean, Home Depot for example, can/does mix oil or latex paints to match any sort of color sample you bring in by placing it in their computerized photo sensor. Typically, paint is mixed by adding the different pigments needed to a neutral base....I don't know if Rustoleum even makes a neutral base or if they could use white. Has anyone ever had Rustoleum or Tremclad custom mixed and if so, where and what was the outcome?
Wm
HeepToJeep is offline   Reply With Quote
Old 05-31-2008, 12:07 AM   #65
Mr_McNasty
Also, wansn't it a b!tch to paint the windshield crevices and such? I was looking at my jeep today and I noticed all the different areas that would need to be painted on the inside as well and it kind of turned me off on the subject.
1998 Wrangler
O|||||O
Old 05-31-2008, 11:16 PM   #66
HeepToJeep
1982 CJ8
I think most folks feel it's worth the effort because you get a quality paintjob for less than $100......seen any bodyshop quotes for paintjobs lately? YIKES!
Wm
Old 06-01-2008, 01:31 AM   #67
Styluss
Wow, so you "painted" the whole thing in Herculiner, then painted that blue? That is just sick. I just painted my car pretty much this same way (1989 Beretta) but I would have NEVER thought of using herculiner with this sort of application!
Absolutely awesome.
Styluss is offline   Reply With Quote
Old 06-01-2008, 11:18 AM   #68
JEEP97TJ
Absolutely awesome.
Well, no. He put Herculiner on the Inside of the Jeep--Floor boards, wheel wells, etc. He painted the outside blue, and some areas of the inside that leave paint exposed.
I must commend you on the great painting job. Those pictures of the Jeep all put back together are amazing, the blue and black looks very good. Great job.
Blacksburg, VA
JEEP97TJ is offline   Reply With Quote
Old 06-03-2008, 01:19 PM   #69
choeyreplied
so did you roll this on, or brush it on?
What kind of brush? the sponge type ones or bristle?
Old 06-07-2008, 11:01 AM   #70
Sahara Matt
Sahara in Disguise
Sahara Matt's Avatar
Sorry I did not answer you sooner. I haven't had time to check this out for a while. I really didn't keep track of what everything cost. I really should have because that was the main point. However, it all depends on what you already have. I wound up buying everything, from the plastic sheeting I put down to any cloths I used. Also factor in the Herculiner, any tools that I didn't have, which was a lot. Buying the Rockers, even saw horses I used to make another bench to work on. MY - total for everything including tools I had to buy that I didn't have probably brings my total to about $700
If you are only buying the supplies to paint, not including the herc. It shouldn't cost more than $100.
The main paint supplies where:
2 cans (quarts I think) of the rustoleum. I didn't even use all of it.
Mineral Spirits.
2 packs of the 3-pack small yellow rollers from HD.
A mini paint tray.
Blue painters tape.
A big sheet of plastic. Got mine at HD for $3 I think.
A mask or two helps.
400, 600, 800, 1000 grit wet/dry sandpaper I got from advance auto parts.
Some 60, 100 and green pads. Used to rought the factory paint.
Krylon Fusion for the flares.
Rustolem high performance (spray) used for the inside of the winsheild.
Decals I bought were about $40.
A sponge
Thats about everything for just the paint. I also fixed my bumper, herc'd the inside and roll-bars. bought the rockers unpainted so I had to buy paint for them. Bought a bunch of new tools, from sockets to a little red craftsman stool and creeper. Some extra lighting from harbor freight when I was working at night. A fan to blow the fumes out of the garage. It can add up quick so make sure you know what you are getting into.
As for the amount of time, I'm not really sure. I guess I started in late Febuary, early March. Taredown took a lot longer than expected. Then the prepping. I made sure to do it right the first time. I tried to work on it for an hour or 2 every night afterter work. I did miss a full week here and there. I wanted to let each coat of paint dry overnight also. I finished up the painting and reassembly in late may. Now, if you had a full week with nothing else to do you could probably knock it out. Took a while but it was fun and I did it myself
Now a Blue Jeep
MY Poor mans paint job and herc, az- rockers, plus flush mount cirlce taillights
http://www.jeepforum.com/forum/f27/my-poor-mans-paint-job-herculiner-560064/
Sahara Matt is offline   Reply With Quote
Old 06-07-2008, 11:08 AM   #71
Sahara Matt
Sahara in Disguise
Absolutely awesome.
JEEPTJ97 cleared up the confusion, and thanks for the complements. But styluss, that is funny that you see this becuase I was on your site when I was doing this. I originally was reading off that mopar forum thread and about half way through my project I found yours and was given even more hope that it would turn out ok. I must have read it 5 times. Good work on doing it outside. That must have been tough. Yours turned out great. Really impressive. I never would have even guessed you were on a jeep forum.
Now a Blue Jeep
Old 06-07-2008, 11:12 AM   #72
Sahara Matt
Sahara in Disguise
I rolled the paint on. I don't think brushing would work at all. Look at the first page of this thread. The foam roller is in the picture with the paint sitting on top of it. The are high density foam. I got mine at home depot in a 3 pack. Used 2 packs. I also bought a pack of small foam brushes for dabbing in hard to reach areas.
Now a Blue Jeep
Old 06-08-2008, 11:40 AM   #73
Mr_McNasty
Nice, because I was going to take a week off of work and go to town on this project.
1998 Wrangler
O|||||O
Old 06-09-2008, 07:52 PM   #74
Sahara Matt
Sahara in Disguise
Good luck. You keeping it blue? I always wanted a blue jeep and that color came out really nice. PM me if you have any questions along the way you need help with.
Now a Blue Jeep
Old 06-12-2008, 09:53 AM   #75
hendu3270
I think I would have sprayed it, but Dayum!!!!!!! dude! That looks really sharp! Great job. Like a few others have said I can't wait till mine is not my DD so I can really tear into it.
hendu3270 is offline   Reply With Quote
Glock Forum
