Quantcast MY poor man's paint job and herculiner - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > General Jeep & Off-Road Equipment > MY poor man's paint job and herculiner
1984-2001 Jeep XJ Cherokee Lift Kits 3-4.5" with FullIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSpartan Lockers FREE SHIPPING Excellent Prices
Old 05-18-2008, 09:00 PM   #1
Sahara Matt
Sahara in Disguise
Sahara Matt's Avatar
So I finally got started doing something I always wanted to try. My jeep is not longer my daily driver. I don't have the funds to build it up yet with buying a new house and a kid on the way. But I have been intigued with reading about people paiting cars with roll-on paint for low cash. I figured I would give it a shot.
First- this is my experience and how I went about doing this. I'm sure there are write-ups of exactly how to do this and I'm sure they work better. This is just how I am doing it.
This is the before picture:
Now a Blue Jeep
MY Poor mans paint job and herc, az- rockers, plus flush mount cirlce taillights
http://www.jeepforum.com/forum/f27/my-poor-mans-paint-job-herculiner-560064/
Sahara Matt is offline   Reply With Quote
Old 05-18-2008, 09:11 PM   #2
Sahara Matt
Sahara in Disguise
Here are supplies I used. The herculiner, and the paint and rollers.
Along with other things like:
- Automotive sand paper. The wet and dry kind.
400, 600, 800, 1000 grit.
- mineral spirits
- water bottle
- Scouring pads
- Plastic sheeting
- blue painters tape
- paint tray
- basic mechanics tools to take apart your jeep.
Everything I bought came from Advance Autoparts and Home-Depot
I'm sure I'm missing some things but I'll mention them as I go.
Now a Blue Jeep
Old 05-18-2008, 09:38 PM   #3
Sahara Matt
Sahara in Disguise
First step in dissasembly I did was take the fender flares off.
Started taking the seats out.
Tailights, rear bumper, license plate holder.
And on and on.......
Now a Blue Jeep
Old 05-19-2008, 11:26 AM   #4
94WorknProgress
good luck with the paint, i did mine the same way in march, i am very happy with it. only tip i have is, order the jeep emblems that you are going to paint over, it just doesn't look the same after they've been painted over.
94WorknProgress is offline   Reply With Quote
Old 05-19-2008, 11:44 AM   #5
acadian
2008 MK Patriot
Wow, I've never heard of doing this. Good luck!
acadian is offline   Reply With Quote
Old 05-19-2008, 07:59 PM   #6
Sahara Matt
Sahara in Disguise
Set aside plenty of time to take your jeep apart. It takes a lot longer than you think it will. Use some cardboard boxes for the bigger parts, small boxes, plastic bags or whatever else you want for the bolts and screws. You will be glad you did.
Now a Blue Jeep
Old 05-19-2008, 08:02 PM   #7
Sahara Matt
Sahara in Disguise
Almost ready to start prepping for the Herc.
Take a wire wheel to any of the surface rust.
Now a Blue Jeep
Old 05-19-2008, 08:19 PM   #8
Sahara Matt
Sahara in Disguise
You can use what you want to scuf the surface. I used one of those green scouring pads.
I used blue tape to cover the areas I didn't want Herc on. You might want to use two pices of tape. It is easier when you try to take it off.
Now a Blue Jeep
Old 05-20-2008, 08:34 PM   #9
Sahara Matt
Sahara in Disguise
When laying down the Herculiner, I used the roller in slow back and forth motions. i used a paint stirrer to spread it on the roller. This way it isn't to thick. I did two coats. I also used a couple of foam brushes for the hard to reach places. In addition to the floors and inside I also did the roll bar. I wanted to paint it back anyway so I figured I might as well use the Herc. I let it dry overnight between coats.
i also did my tuffy storage console.
Now a Blue Jeep
Old 05-20-2008, 11:45 PM   #10
ih8pepl73
Looks good but GD that's a lot of work!
Someone tell me how to line the exterior panels!!!
Originally Posted by The_TwStD_1 View Post
Procrastination's a lot like masturbation. It's all fun and games until you realize you're only screwing yourself.
Originally Posted by ih8pepl View Post
Jeeps are one vehicle that should never have anything stamped with "Made in China" attached to it!
Definitely a 2004½ Unlimited.
ih8pepl73 is offline   Reply With Quote
Old 05-21-2008, 06:38 PM   #11
Sahara Matt
Sahara in Disguise
Now on to the painting. This is where I made my first big mistake. Not doing my research, I thought I had to take the paint down to bare steel. 1- that would take forever. and 2 - it is a lot harder when I tried to do it with and air sander. When I realized I could just scuf the paint and then paint over the original it was to late. To fix my mistake I used primer on the bare steel and then tried to sand it back to even level. Didn't work to well. I didn't have the patience. Plus, its a jeep. It doesn't have to be perfect. For me anyway. So that is the reason the next pictures look the way they do.
Here it is taped off and scuffed with one of those green pads again. I stripped as much of the jeep as i could without going overboard.
Now a Blue Jeep
Old 05-21-2008, 06:45 PM   #12
officialvin
looked fine befoe.. why ruin a a good paintjob with a not properly done roll on job?
officialvin is offline   Reply With Quote
Old 05-21-2008, 06:45 PM   #13
Sahara Matt
Sahara in Disguise
Its also easier to take the hood off and paint it off the jeep.
Now on to the painting. Mix the mineral spirits with the paint. I used a about a 1:2 ratio. 1 part mineral spirits for 2 parts paint. Use a small paint tray. About $1 from Home depot. Its easy to move around the jeep as you work. Do a section at a time. Biggest trick is make sure there are no runs.
Here is what it looks like with the first coat of paint. What ever you do, try not to roll it on to thick.
Now a Blue Jeep
Old 05-21-2008, 07:09 PM   #14
JEEP97TJ
Sorry, but I have to second this....I'd love to have a green sahara Jeep.(I'd trade my blue one haha) Though I will reserve my final opinion until the 'After' pictures....
Blacksburg, VA
JEEP97TJ is offline   Reply With Quote
Old 05-21-2008, 07:10 PM   #15
Sahara Matt
Sahara in Disguise
Don't be discouraged if it looks like that after the first coat. It may take 4 coats just so none of the paint underneath is visible. I forget what coat I was on in this picture but you see that it is getting better. I think it was after 3 or 4.
You need to wet sand every 2 coats.
coat 1 ,2 then wet sand with 400 grit
coat 3, 4 then wet sand with 600 grit
coat 5, 6 then wet sand with 800 grit
coat 7, 8 then wet sand with 1000 grit
after 8 coats you should be good. You can polish the paint and make it shine. After my 8th coat I wet sanded and then did one more coat for good measure.
Now a Blue Jeep
Glock Forum
