My jeep will not stayin the road - JeepForum.com
post #1 of 6 Old 10-17-2013, 04:06 PM Thread Starter
oleblackie
Had my jeep out for a drive the other day and it was all over the road. It has always done this but not this bad. Does anybody have an idea of what might be going on or what needs to be fixed.
oleblackie is offline
post #2 of 6 Old 10-17-2013, 06:35 PM
uberxj92
1992 XJ Cherokee
What yr make model? There's several causes.
There's alignment, tires, rims, ball joints, tie rods and ends, the steering box, bushings.
start with steering components, motor off have someone turn the wheel slowly side to side look for play or looseness.
The steering boxes have slack adjustments.
Check wheel bearings and ball joints by jacking the tire up and grabbing tire, shake it from top to bottom and left to right. Shouldn't have play there.
Rotate tires front to rear.
The very last thing you should do is mess with the stabilizer. It will mask the rear issue.
On a softer note if you're my uncle mike, stop drinking. Lol it will steer right lol. Just kidding
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline
post #3 of 6 Old 10-17-2013, 10:47 PM
222Doc
222Doc's Avatar
just tore apart our 012; ball joints. started driving like your uncle Mike..
222Doc is offline
post #4 of 6 Old 10-20-2013, 01:39 AM
Indy
Indy's Avatar
Theres something wrong with your:
Tires
Wheels
Suspension
Alignment
Steering assembly
Frame
Etc.
Or a combination of any of the above. Best diagnosis possible over the internet.
I'm the only gay eskimo.
Indy is offline
post #5 of 6 Old 10-20-2013, 08:59 PM
Shark_13
Check all tire pressure.
Check toe-in.
Check all tie rod ends/steering.
Check ball joints.
Check track bar.
Dry steer test, have someone move steering wheel back & forth engine off & look for play around all joints.
Shark_13 is offline
post #6 of 6 Old 10-21-2013, 08:38 AM
1222
RIP John
1222's Avatar
Stop drinking, problem solved.
Sorry, just had too. Anyhow, as you can see from the above posts there can be all kinds of reasons for the way your Jeep handles. If I were you I would start trouble shooting from the easiest and work your way up. For instance tire pressure and then ...
1222 is offline
