My 2012 Cherokee's engine won't shut off!!! Help - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > General Jeep & Off-Road Equipment > My 2012 Cherokee's engine won't shut off!!! Help
FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri2007-2016 Jeep JKU 4" X-series suspension lift **deaThe Cure for your Tie Rod Roll!
Unread 12-31-2012, 04:22 PM   #1
Tyandbrit
Okay, really weird but my engine won't shut off. I'm on a road trip and when I got to my destination it wouldn't shut off! There is nothing in the manual for it but tried the remote start, button even the key itself. Even disconnected the battery without avail. It ran for about an hour more and then randomly turned off after I got in and the key buttons got pushed in my pocket. I was out in the middle of nowhere so didn't push the issue. Today didn't have trouble starting it but again, it won't shut off. The company party line is to take it to a dealer but I have another day of driving before I get back home. I was hoping some jeep experts could help. Thank you in advance!
Tyandbrit is offline   Reply With Quote Quick reply to this message
Unread 01-01-2013, 11:27 AM   #2
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
Dont know why it did it, and am guessing it is a Grand Cherokee, not a Cherokee?
Either way, to shut it off in the future if needed, There are various relays you can pull.
Fuel pump, injectors, ignition, etc.
Have a look under the hood in the fuse and relay box, and look at the relays so you know which ones to pull.
Martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
http://www.jeepforum.com/forum/f12/swap-offically-underway-324622/
leftlanetruckin is offline   Reply With Quote Quick reply to this message
Unread 01-01-2013, 09:21 PM   #3
moses21
Im confused on how discounecting the negative ground for the battery wouldn't turn the car off. Thats really weird.
moses21 is offline   Reply With Quote Quick reply to this message
Unread 01-02-2013, 09:59 AM   #4
leftlanetruckin
XJ on 37's
Not really.
I have had more vehicles run with a battery disconnected, than not.
Martin
http://www.jeepforum.com/forum/showthread.php?t=324622
Unread 01-04-2013, 11:16 AM   #5
IslandTJ
Location: where I wheel: N 45║ 36.663' W 123║ 20.935', Oregon
I believe it's because of the Jeep's alternator. Once on and engine running, the alternator is the primary device that supplies electrical power to the Jeep; the battery in turn, is now the secondary source of electricity.
1998 TJ Moss [COLOR=darkgreen][B][SIZE=3]Green[/SIZE][/B][/COLOR] Sahara w/ numerous scratches & dents whose playground is on a tropical island that's 33 miles long and 4-12 miles wide, in year-round 82 degree weather.
[Edit] "Now jeepin in Oregon" [/Edit]
IslandTJ is online now   Reply With Quote Quick reply to this message
Unread 01-04-2013, 11:45 AM   #6
moses21
Ohh ok. You learn something new everyday!!!
Unread 01-05-2013, 09:57 PM   #7
wheelin
WIN. Wireless ignition noid. Which is your ignition switch probaly bad. Take it to a dealer
95 yj
wheelin is offline   Reply With Quote Quick reply to this message
engine , shut off
