muddin - JeepForum.com
post #1 of 44 Old 03-30-2003, 07:57 PM Thread Starter
94 sweet sahara
muddin
What's the basics of muddin. Like are there any tricks out there, besides common sense?
94 sweet sahara is offline
post #2 of 44 Old 03-30-2003, 08:11 PM
Devious
Hobo Shanker
Devious's Avatar
2014 JK Wrangler
Good tires, decent amount of lift and some horsepower is a good start.
Life is tough enough already, but it's even tougher when you're stupid
Devious is offline
post #3 of 44 Old 03-30-2003, 08:16 PM
Dembones
Dembones's Avatar
It's all about speed. Don't let your tires stop spinning. Gun it all the way through. Turn your windshield wipers on high BEFORE hitting the mud. I usually make it to 5th gear through the middle, just remember to gear down before you hit dry ground. Keep it in 4hi unless you get stuck, then try 4low, steering back and forth while going forward and reverse. Good luck and have fun Oh yeah, don't let the mud sit on your Jeep more than a day, especially in the heat. It will screw up your paint. It's a good idea to coat your paint and wheelwells with cooking oil before going out, keeps the mud off.
Blue '94 Wrangler, 2.5L: Under monsterization
37" Claws/teralow/HPD44/Trussed HI9/5:38s/detroits/SOA, shackle reversal on rebuilt waggy and XJ springs.
Blue Jeep Club member 2
Dembones is offline
post #4 of 44 Old 03-31-2003, 04:11 AM
BamaJeeper
BamaJeeper's Avatar
Go slow, especially if you don't know how deep it gets. I once was creeping along beside a mudhole and decided to put one tire in and fell into a 44" rut. The snorkel saved the motor that day!
Oh yeah. Don't go alone.
Out of the darkness comes light.
BamaJeeper is offline
post #5 of 44 Old 03-31-2003, 11:48 AM
clarky711
I second the "don't go alone" tip, using my hilift as a winch gets old quick!! And bring a camera!
Mike
01 Sport, 4.5" RE LA, 35" BFGs, 4.88 gears in Dana 44s, ARB up front, Eaton E-locker in back, Warn XD9000i, and a bunch of other goodies.....
Previously: 01 TJ on 32s, 94 YJ on 33s, 89 xj on 31s, 97 TJ on 31s, 79 CJ5 on 31s.
clarky711 is offline
post #6 of 44 Old 03-31-2003, 04:26 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Ditto on the don't go alone thing. Also, try to egg on the other driver so he/she drives into the holes first. Once in the mud, I like to put it in 3rd gear/low range, bring the RPMs up to about 3 grand, side step the clutch and bring it up to about 5500 RPM even if I get stuck, it still sounds cool..
BESRK is offline
post #7 of 44 Old 03-31-2003, 07:43 PM
BIG SEXY
BIG SEXY's Avatar
Get a good dog that you can take with you!!!
This is what I do when we go ridin 4-wheelers, let the dog run in front of you. If the dog disapears, DON'T GO IN THERE!!!
91' YJ,4.0 I-6(180,000 mi) 2" Rancho Add-A-Leaf kit, 1.5" shackle lift, 2" BL, 33x12.50 BFG M/T KM's, 15x8 589's, TJ flares, custom F&R bumpers w/ swing-away spare carrier & rocker guards, FULL ROLL CAGE, herculiner, Warn XD9000i (IT'S ALSO MY WIFES... or was!!!)
Rig Rater score= 476RRv1.0
Its a dog-eat-dog world. and I'm wearing MILKBONE UNDERWEAR!!
BIG SEXY is offline
post #8 of 44 Old 03-31-2003, 08:17 PM
Swamp Boy
Swamp Boy's Avatar
I just go for it.. I get to the edge of the hole and then I go at
it balls to the wall.. Works for me 90% of the time..I go places
that others cant. Then I pull them through..Like here
here is me pulling out a toyota that is strapped to a datsun ..
See it in the back.. I pulled them both out at once..
Thank god for V8's ..
Never go charging into mud holes you just end up like this.
Like I am sure lots of people will tell you .. Slow and steady ..
You want to maintain momentum ..That is the most important
thing..Dont have to go fast just dont stop.. I have seen people
stop and get stuck in holes that look like a bicycle could go thru..
Like this
He is completly stuck and you can see my tracks right in front of
him.The hole is deep in the middle but he went to the side and
his back tire is stuck on a tiny bump but when he hit it he stopped
then he couldnt get over it.. Very sad...It looks like he is stuck
in a piss puddle..
Hope this long post helped...
Have fun, never go alone get a good strap and tow hooks..
Just another soccer moms Grocery getter....
Swamp Boy is offline
post #9 of 44 Old 04-01-2003, 08:24 AM
MudLover
MudLover's Avatar
Hey BESRK !! I thought you got shipped out? What you been yup to. I've missed ya around here.
Marc
1979 CJ5 project
"Life is an issue of mind over matter. Ya see, I don't mind, and well...you don't matter."
Red Jeep Club Member #2
MudLover is offline
post #10 of 44 Old 04-01-2003, 08:35 PM
AKULARED
Thats the first i heard of that one...
like rainx on mud? yah?
AKULARED is offline
post #11 of 44 Old 04-01-2003, 09:08 PM
Dembones
Dembones's Avatar
Ya, I used to wax the whole thing before going out, but that got old real quick. Cooking oil does the same thing, if it doesn't keep the mud off it will at least make it alot easier to wash off afterwards.
You are all right. Speed happens after the depth is found (by dog or person ) and you're sure there's no big holes. I got stuck in a "W" shaped rut when I bombed into a 4' wide puddle. ALWAYS check the depth first and either bring a friend or a good winch.
Dembones is offline
post #12 of 44 Old 04-02-2003, 05:57 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Turkey closed the door in our face so I'm here in VA waiting on a short leash. I'm gonna get in as much Jeep time as possible though! I already started helping my buddy swap in a pair of locked 4.56'd Dana 44's and a 401 into his CJ7. Hope I finish before leaving or he'll be walking for awhile. As to the muddy Jeep thing... I just use Greased Lightning on everything when I'm done. Spray it on and just hose it off... minimal scrubbing, even on tires and soft top.
BESRK is offline
post #13 of 44 Old 04-02-2003, 05:14 PM
vball1socr4
where in NN are you???
vball1socr4 is offline
post #14 of 44 Old 04-02-2003, 05:49 PM
StuckInMuck
I had to register just to tell you that, when i read this i laughed out loud here at school, lol, i almost got busted but its night school and were all adults, haha..But yeah im lookin forward to bein around here alot, for in 3 weeks im purchasing a jeep and goin to a big 4-wheelin avent in Ashboro, NC..Cool cool
StuckInMuck is offline
post #15 of 44 Old 04-02-2003, 06:04 PM
93jeepyj2.5
93jeepyj2.5's Avatar
I think the key is to get into the mud at a slower pace then start spinning the tires instead of hitting it wide open.
-Heath
93 Black YJ, locked and on 33's----Sold
03 TJ Sport.....31" MT/R's on MT Classic II's
93jeepyj2.5 is offline
Keep traction while muddin or8008 Tires & Wheels 20 01-27-2005 03:13 AM
