Mud and Water safe? - JeepForum.com
post #1 of 4 Old 04-11-2004, 07:05 AM Thread Starter
OwnAccord
Mud and Water safe?
I went out to Paragon last weekend and had a lot of fun in the mud and water. At times, the mud made it up over the hood. The mud was almost over my half doors!
Is there something I should do in the way of post-maintenance now that I ran through all of this mud and water? Is mud and water bad for the under-parts? Should it really be avoided?
OwnAccord is offline
post #2 of 4 Old 04-11-2004, 09:27 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Your transmission has a vent on top of it that can allow water (muddy water?) inside. I'd be draining the tranny and refilling it if you got that deep. Make sure the rubber vent hoses that keep water out of your axles are both still firmly attached to the tops of the axles, otherwise water could have gotten in one of them too. The transfer case also has a vent hose like the axles do but its hose is out of the way and normally pretty safe from getting knocked loose so it won't likely let water inside.
Jerry Bransford is online now
post #3 of 4 Old 04-11-2004, 12:41 PM
MSHarnett
Broke Bogger
MSHarnett's Avatar
For future referance, you should put some dielectric grease on the wiring harnesses. I kept blowing my O2 sensor fuse and could figure out why. 2 sensors later I relized that the water wasn't ruining the sensor, it was just shorting out the plug.
Like Jerry said, tranny, diffs, and t-case. Whatever you do, do not go any deeper than your air intake. That makes for a misrable trail fix .
Matt
MSHarnett is offline
post #4 of 4 Old 04-11-2004, 08:24 PM
CanukYJ
CanukYJ's Avatar
For water above the headlight (stock air intake) make a mini snorkel for 5$ like I did and get the inake level with the hood and no one will ever see it.
My jeep has only ever killed 3 things, a cat, a deer, and my wallet. What's the problem officer?
1992 Red YJ. Lifted, locked, and loaded with beer (Disclaimer: This doesn't mean said driver endorses drinking and driving, please enjoy alcohol responsibly and do not operate any vehicle of any kind, thank you....)
Thanks to the price of gas here ($4.25 a gal) I just bought a mountain bike, 0" of lift, 0" of travel, MT's, locked rear axle, oh yeah, it's the sh#$.
CanukYJ is offline
safe PSI to run on rock ? 89_Jeeper Tires & Wheels 19 05-14-2008 05:40 PM
Bl's safe? eclipse27 General Jeep & Off-Road Equipment 20 10-24-2006 07:34 AM
Be Safe!!! GrimJeeper91 General Jeep & Off-Road Equipment 29 06-14-2004 01:38 PM
Water proofing for water crossings kchan2752 General Jeep & Off-Road Equipment 1 05-02-2004 08:12 PM
Water Proofing, or Water proof Alternators? DaveFL General Jeep & Off-Road Equipment 5 06-15-2003 04:03 AM
