Quantcast mods to seat brackets - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > General Jeep & Off-Road Equipment > mods to seat brackets
Old 01-03-2006, 10:43 PM   #1
MissileTM
I recently purchased a set of APC Racing Seats really cheap for my 95 yj and mounted the pass side and noticed that it is just too high. My feet almost dangle above the floorboard! Without tilt, I don't think I would be able to drive with my knees so close to the wheel.
I was thinking about making all new mounts, but thought it may be easier to just modify the existing ones if possible. I searched a lot on here and a couple other fourms..... not much luck.... Anyone have a similar problem? should I chop and re-weld the stock mounts?
Thanks for your advice in advance.
MissileTM is offline   Reply With Quote
Old 01-04-2006, 05:59 AM   #2
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I had the same problem when I mounted racing buckets in my CJ5.. just cut/reweld the original frame.
'80 CJ5 w/AMC360, T176, D44 w/Detroit 3.73s, RE 4" YJ lift and 35s..
Ground Pounder Fab
Lower 2
Guardrail
Down Schoolbus
Slickrock Tellico
Save
Crozet
More Crozet
BESRK is offline   Reply With Quote
Old 01-04-2006, 11:04 AM   #3
Rodeo1488
By These Things I Stand !
Rodeo1488's Avatar
I bought some new seats on Christmas Eve. I'm just going to make my own mounting plates for my seats.
White Jeep Club Member #1488
"Sometimes, there's Justice.......Sometimes, there's Just Us. "
- Living my life on a Thin Blue Line -
Originally Posted by HolidayJeep
If that doesn't work, here's what you do. Buy a bunch of burritos and tie them to pieces of string. Then tie the strings to your Jeep. Then, when the meskins come out of the house drawn by the smell, you drive away. The meskins will chase burritos for miles and miles.
Rodeo1488 is offline   Reply With Quote
Old 01-04-2006, 12:34 PM   #4
MissileTM
Rodeo....
What do you have planned for the new mounting plates? I have been thinking of doing that as well.
Old 01-05-2006, 09:24 PM   #5
paultyler
Uncle Paul has spoken...
paultyler's Avatar
Same problem for me with the Bestop TrailMax seats. I removed the slider and mounted the seat directly on the bracket. This lowered the seat 1 inch. But you will not be able to slide the seat forward.
Edit: Wife got in my jeep and could not reach the pedals. Got mad at me. I took the seat to an upholstry shop and had them cut out 1.5 inches of padding off the bottom of the seat. Now I can put my sliders back on.
My Jeep - Video
My Jeep in the Snow
92 YJ, 35' MTR Kevlars, Klune/Dana 20, 4.88s, SYE, Rubicon D44s w/Rubicon lockers, front and rear Alloy USA chromoly shafts with 30 spline outers, JK electric swaybar, T&T tube fenders, custom cv driveshafts, RE 4.5 XD springs, M.O.R.E. 5/8'' boomerang shackles + 2' BL, 15lb Powertank, 4.0L TB & TB spacer, ARB Snorkel, K&N filter, rear bumper and tire rack, Rancho 9000s, AtoZ Rockers, Skid-Row Engine skid plate, Teraflex Bellyup, JCR Offroad 1 Ton TieRod, rock lights, RE hand throttle, M.O.R.E. roll cage, corners, 9000lb winch with synthetic cable in-cab winch controller (12voltguy.com), Dual Blue Top Optimas with 12voltguy dual battery controller, a/c (ackits.com)
Originally Posted by joshrad View Post
This Uncle Paul guy seems to know what he's talking about.
paultyler is offline   Reply With Quote
Old 01-06-2006, 12:22 PM   #6
Rodeo1488
Rodeo1488's Avatar
I'm looking at getting some 1/4" to 3/8" sheet metal and forming thim to the old mounting points on my new seats. I'll be doing a write-up on it a little later.
Glock Forum
