Mini Harbor Freight (type) Trailer Ultimate Build-Up Thread - Page 8 - JeepForum.com
 38Likes
post #106 of 3054 Old 09-28-2011, 08:51 PM
KLT88YJ
Jscherb: That's just some awesome CAD design! I've seen some of your work on the forum and in the mags! Sooo...your "Jeep" tub would Just bolt to the harbor freight frame!? If you plan on producing it?
KLT88YJ is offline
post #107 of 3054 Old 09-28-2011, 08:54 PM
jscherb
Yes, it would bolt to the HF frame. I'm in the process of making the molds right now; they'll be capable of making any length Jeep-style trailer tub up to 8' 7" long, so you could make one for the mini HF trailer or the 4x8 HF trailer or anything in between. I'll probably start a thread on the project soon so everyone can see the details as it progresses.
"Whether you think you can do something or you think you can't, you are right" - Henry Ford
jscherb is offline
post #108 of 3054 Old 09-28-2011, 11:33 PM Thread Starter
armyRN
armyRN's Avatar
Location: Longview, WA (one hour north of Portland, OR)
That'd be cool to have a lid on it to keep your gear dry. But I assume that a taught bungied down tarp would provide the same affect!
I'd be building one of these "behemoths" in my shed (14x18) as I don't have a garage. Is the finished product fairly heavy? I have roughly a 1.5-2 foot drop/ difference from the shed to the ground. I'd also need to check my door widths (2 folding doors) they're approximately 2.5-3 feet wide, should be more than adequate.
It comes with the title/information too right...? So you'd just be going for inspection then to the MVA for tags n such!?
ArmyRN: Do you have any current/ update photos!? Driveway, loaded/ unloaded, action shots...ect!!??
You will probably need two people to get the trailer over the drop. Not that it's so heavy (it's not a lightweight though) but it is awkward and bulky. But totally doable with two healthy dudes.
My trailer came with paperwork that I just brought to the tag place (just the paperwork - I didn't bring the trailer) and they sold me a tag. They actually gave me the option of a regular sized tag, or a smaller tag. I went with the smaller tag, and was glad I did.
No new pictures. I mounted an ammo can on the tongue for the spare hub and bearing set, but I was going to wait until the two 1.5 gallon Kolpin fuel tanks came in (that'll match the rear 4 gallon fuel can on the rear) and got them mounted one each on the sides in front of the fenders before taking pictures. Right now the trailer is parked in the garage being used as the "empty cardboard box storage unit". I was going to take a picture of it connected to my 46 Willys after mounting the ammo can, but the receiver hitch was just a little too long for the pin hole to line up on the Willys' receiver (thanks for reminding me - I need to get it trimmed).
Edit...
Ok, I went out in the garage and took a few. As you can see, the trailer pulls double duty when parked in the garage (box storage unit). The ammo can had to be mounted a little more forward than I wanted, but I had to place it there in order to be able to have room to remove the spare tire. The ammo can also is low enough so when the tailgate swings out it goes over the ammo can (and it just barely misses hitting the trailer's spare tire when swinging out). The last picture is just of my other garage toys.
pumpkin, Ava, and Trailer ammo can 0031.jpg   pumpkin, Ava, and Trailer ammo can 0041.jpg   pumpkin, Ava, and Trailer ammo can 0051.jpg
armyRN is offline
post #109 of 3054 Old 09-29-2011, 04:39 AM
KLT88YJ
Thanks for the pics. I really think this little trailer is what I'm looking for, gets the gear outta the Jeep = more room for the wife, kid and dog!!
That's a nice looking 2A! Is that a 3A or M38 windshield? Either way its stronger than the 2A. I had a 47 2A that I had been working on, just got to be too much (no garage and a small child).
KLT88YJ is offline
post #110 of 3054 Old 09-29-2011, 07:26 AM
Deuskid
armyRN-
How did you attach the ammo can?
Also, would it have worked to turn it 90 degrees, along the same axis or would that have caused a conflict somewhere?
Love this concept and will probably implement it but need to get a jeep first
John
Deuskid is offline
post #111 of 3054 Old 09-29-2011, 04:50 PM Thread Starter
armyRN
armyRN's Avatar
It's a 3A (I think - it was on the Jeep when I bought it) windshield frame. It just had a cover plate over the center opening under the windshield. Definitely stronger than a 2A windshield frame.
armyRN is offline
post #112 of 3054 Old 09-29-2011, 05:04 PM Thread Starter
armyRN
armyRN's Avatar
Originally Posted by Deuskid View Post
armyRN-
John
Where the two angled braces come together on the tongue to form the tip of the triangle, there are two carriage bolts side-by-side (one for each brace). I replaced them with bolts and large washers, and drilled two holes in the ammo can floor for these bolts to go through. I also drilled two holes under the other side of the ammo can (one through each of the angled braces) to secure it there also with two smaller bolts/washers. I used nylocks so the bolts wouldn't shake loose. So it is secured in four places - it's not going anywhere.
I didn't think of mounting it 90 degrees (along the length of the tongue) but it would have worked. The ammo can base is 11" long. It would not have caused any interference as far as I can tell (I was out there with a tape measure before typing this). My tailgate swings above the ammo can, so that's not an issue.
One thing to remember, is the "Red" trailer's tongue is about 10" shorter than the "Black" (like mine) trailer's tongue. If you're mounting a spare tire carrier like I did on the front of a red trailer, you might not have enough room to mount an ammo can lengthwise. But ammo cans are light - you could mount them on the wooden sides behind the fender if you wanted.
Here's where I ordered the ammo can:
http://www.ammunitiontogo.com/product_info.php/pName/1-usgi-50cal-ammo-can-new/cName/ammo-cans?osCsid=2k439ot4njhmkpupi225802jj4
You'd think living in an Army town you would be able to find them easily. I found some at my local Army Surplus Store, but they looked like crap. Rusty, poorly repainted, etc. They looked like they had spent a lot of time outside. I didn't want to put an ugly can on my nice looking trailer, so I ordered one of these new ones - and glad I did. With shipping it came to about $25.00.
I seriously considered one of these:
http://store.colemans.com/cart/ammo-box-wwii-50-cal-p-221.html
But after seeing what the used cans at my local surplus store looked like, I was hesitant to purchase one of these sight unseen (I felt safe ordering the new one as above). But having a vintage can might have looked cool (of course, I might have been the only one that ever noticed, but still...).
armyRN is offline
post #113 of 3054 Old 09-29-2011, 05:09 PM
Deuskid
One thing to remember, is the "Red" trailer's tongue is about 10" shorter than the "Black" (like mine) trailer's tongue. If you're mounting a spare tire carrier like I did on the front, you might not have enough room to mount an ammo can lengthwise. But ammo cans are light - you could mount them on the wooden sides behind the fender if you wanted.
Excellent, thanks
Deuskid is offline
post #114 of 3054 Old 09-30-2011, 06:57 AM
padre1964
So many cool designs, thanks for all the different ideas !
padre1964 is offline
post #115 of 3054 Old 09-30-2011, 10:08 AM
95tealxj
Thanks for the ideas, going to build one.
95tealxj is offline
post #116 of 3054 Old 10-02-2011, 10:46 PM
eyeJeep
Here are pics of my HF trailer. I just got all of the sides on today, I hadn't touched in a few months since it has been so dad gum hot here in Texas. I do have a replacement axle in the garage with a 5 lug bolt pattern that needs to be fitted and the wheels in tires to match the Jeep. Of course it will need fender flares to cover the tires too.
Mock up with the original trailer and my spare.
-Eric
'13 JKU Gecko Rubicon
'01 Wrangler Sport Rubiclone
'48 Willy's CJ2A
eyeJeep is offline
post #117 of 3054 Old 10-05-2011, 10:47 AM Thread Starter
armyRN
armyRN's Avatar
Here's a trailer rebuild write-up I found in a recent thread that might give folks some ideas. If I had to do mine over again, I might consider doing the sides in tongue-and-groove lumber. http://www.jeepforum.com/forum/f37/o...oject-1156514/
armyRN is offline
post #118 of 3054 Old 10-09-2011, 06:31 PM
jscherb
I've started a new thread on the fiberglass trailer tub project - the thread is called "Bolt-together fiberglass Jeep-tub trailer kit". The project is to build a bolt-together tub kit that could be used with these Harbor Freight or similar trailer frames.
Here's the link: http://www.jeepforum.com/forum/f9/bo...r-kit-1274811/
jscherb is offline
post #119 of 3054 Old 10-14-2011, 10:45 PM Thread Starter
armyRN
armyRN's Avatar
I mounted some small gas cans on either side of my Jeep. I put a thin steel plate between the lumber slats to reinforce it.
cat, trailer cans, avon jeep 015.jpg   cat, trailer cans, avon jeep 016.jpg   cat, trailer cans, avon jeep 024.jpg   cat, trailer cans, avon jeep 023.jpg   cat, trailer cans, avon jeep 019.JPG
armyRN is offline
post #120 of 3054 Old 10-14-2011, 10:46 PM Thread Starter
armyRN
armyRN's Avatar
A couple more shots. Sorry they're garage shots.
armyRN is offline
Currently Active Users Viewing This Thread: 16 (1 members and 15 guests)
drakethib
Harbor Freight Trailer fishinjeeper General Jeep & Off-Road Equipment 14 07-21-2014 12:02 PM
Little Harbor Freight Trailer armyRN General Jeep & Off-Road Equipment 15 04-20-2011 10:03 PM
Harbor Freight Mini-mill otherwise know as Sieg X2?? MA88XJDude Fabrication Shop 13 03-29-2011 07:50 PM
Harbor Freight Trailer with AT's? Anti-bling General Jeep & Off-Road Equipment 8 12-03-2007 07:37 AM
harbor freight trailer willtjx General Jeep & Off-Road Equipment 3 05-04-2005 07:20 AM
