Mini Harbor Freight (type) Trailer Ultimate Build-Up Thread - Page 57 - JeepForum.com
 32Likes
post #841 of 3037 Old 09-02-2013, 09:38 AM
pentaflex
Originally Posted by kjg26 View Post
For those of you that have replaced the stock tongue with full length square tubing. How did you attach the tubing to the frame? Did you run a bolt all the way through from top to bottom? Did you somehow fish a nut through the tubing? How did you do it? Thanks
Bobdog went with a full-length tongue, but he welded everything. I'm not a welder so if it were me, I think I would sandwich the tongue tube between two pieces of angle steel bolted to the frame. You could then bolt the tube horizontally (and vertically if desired). This would give you more strength and less lateral movement.
Having a full length tongue allows you to have a hitch receiver on the rear, which would be great for a lot of reasons. The stock tongue on the HF trailer is plenty strong though.
pentaflex is offline
post #842 of 3037 Old 09-02-2013, 09:41 AM
kjg26
kjg26's Avatar
I can't invision what you're saying as far as sandwiching the stock tongue with angle
Black 1993 YJ 4.0, 5 Speed
Slowly but surely getting better and better. Trailer build soon!!
kjg26 is offline
post #843 of 3037 Old 09-02-2013, 09:44 AM
Deuskid
I'm wondering why so few builds use marine plywood for the box?
Is it just ascetics?
Seems like it'd be a quicker, easier build, especially if one were going to paint it.
Thoughts?
Thanks,
John
Deuskid is offline
post #844 of 3037 Old 09-02-2013, 09:54 AM
switters88
Thoughts?
Thanks,
John
I didn't choose plywood because of aesthetics personally. I think it looks good with the t&g pine and it's very solid. And because this is my first time building anything and the first time working with wood, I wanted a bit of a challenge. Plus I just wanted a more time consuming project.
2012 Wrangler JKU Sport
1998 Wrangler TJ
1989 Wrangler YJ (sold)
1986 CJ-7 (sold)
switters88 is offline
post #845 of 3037 Old 09-02-2013, 10:00 AM
pentaflex
Just a crude white board drawing, but hope this helps:
Last edited by pentaflex; 09-02-2013 at 10:15 AM. Reason: To clarify, I wouldn't do this with the stock tongue since it is not a tube.
post #846 of 3037 Old 09-02-2013, 10:12 AM
pentaflex
Thoughts?
Thanks,
John
It's very dry here in Colorado, so we don't worry too much about rust or rot. Like switters, I also like the look of T&G and I did not want to paint it. Cedar is lighter than plywood and stands up to the weather naturally (although I did spray on a clear coat water sealer). I used treated plywood for the floor and top.
post #847 of 3037 Old 09-02-2013, 10:40 AM
switters88
Where are you in Colorado?
1998 Wrangler TJ
1986 CJ-7 (sold)
post #848 of 3037 Old 09-02-2013, 10:48 AM
switters88
A quick pic of the trailer hooked up to my '98. I'll be towing the trailer primarily behind my JKU but I have to buy a hitch first.
1998 Wrangler TJ
1986 CJ-7 (sold)
post #849 of 3037 Old 09-02-2013, 11:09 AM
pentaflex
Centennial, southeast Denver
post #850 of 3037 Old 09-02-2013, 11:25 AM
kjg26
kjg26's Avatar
Doesn't the bottom of the trailer have a shape? Or is it flat?
kjg26 is offline
post #851 of 3037 Old 09-02-2013, 11:30 AM
kjg26
kjg26's Avatar
Scratch that. Its a sideways C. correct?
kjg26 is offline
post #852 of 3037 Old 09-02-2013, 12:17 PM
pentaflex
It's flat. The side rails are a C channel, but the cross members are kind of a question mark. (See the manual here.) Where the tongue attaches to the cross members it is flat. The tongue itself is a sideways 'C', but it has several tabs welded on to "close" the C at certain spots.
post #853 of 3037 Old 09-02-2013, 07:16 PM
NMBruce
What about using a straight piece of metal along the inside HF frame above you angle pieces to kind spread the contact point, like a big flat body washer does?
2013 JKUR sold
2006 GX470
I knew I shoulda taken that left turn at Albuquerque! - Bugs Bunny
NMBruce is online now
post #854 of 3037 Old 09-02-2013, 11:04 PM Thread Starter
armyRN
armyRN's Avatar
I was thinking a piece of angle along the crossmember so you've got reinforcement in two planes.
How's your trailer project coming along coops2K?
armyRN is offline
post #855 of 3037 Old 09-03-2013, 08:44 AM
NMBruce
Have not yet started, but one of the local guys has offered to help me build a frame using 2.5 square tubing, so I might get away from the HF trailer. I hope to talk with him this weekend. 8 Jeeps just did a weekend trip to the Ouray area and Fred had his trailer along. You can see pics of his trailer here. http://www.wranglerforum.com/f52/our...ml#post4235769
I would still do the simple box, T&G or "Bear Box", just a lot stronger frame.
2013 JKUR sold
2006 GX470
Currently Active Users Viewing This Thread: 9 (0 members and 9 guests)
Harbor Freight Trailer fishinjeeper General Jeep & Off-Road Equipment 14 07-21-2014 12:02 PM
Little Harbor Freight Trailer armyRN General Jeep & Off-Road Equipment 15 04-20-2011 10:03 PM
Harbor Freight Mini-mill otherwise know as Sieg X2?? MA88XJDude Fabrication Shop 13 03-29-2011 07:50 PM
Harbor Freight Trailer with AT's? Anti-bling General Jeep & Off-Road Equipment 8 12-03-2007 07:37 AM
harbor freight trailer willtjx General Jeep & Off-Road Equipment 3 05-04-2005 07:20 AM
