Mini Harbor Freight (type) Trailer Ultimate Build-Up Thread - Page 53 - JeepForum.com
 32Likes
post #781 of 3037 Old 08-17-2013, 08:47 PM
Sahara707
Congrats! Mine should should be here Friday
Sahara707 is offline
post #782 of 3037 Old 08-18-2013, 06:53 AM
Deuskid
Originally Posted by gouacats View Post
I'm not planning on taking mine on that rough of trails, but hopefully, the modifications, as suggested by jscherb, made to the "heavy duty" HF trailer will keep this from happening.
what are the final dimensions for your frame? I was thinking of going the same route, 4x8 modified smaller and using salvaged parts to beef up the frame.
Like you, I'm not going to be going on extreme trails but would rather over-build from the start and never worry about a frame fail.
I'm still trying to determine what exactly I want. I'd like a box but want to be able to easily remove it for storage [I'm going to have to keep it on end in my 2 car garage with a car and a Jeep]. Also want a rack [jsherb posted a neat idea about that in his bolt-on thread yesterday]... anyway I digress....
Like you, I wonder if the modified, strengthen HF frame will be stout enough to avail failure?
John
Deuskid is offline
post #783 of 3037 Old 08-18-2013, 08:21 AM
azcat
Originally Posted by switters88
Hello all. I posted on azcat's build page this morning and thought I'd pose a quick question over here as well. I'm building up a little 40x48 HF trailer and so far I have the floor and three walls built. However, I'm a little stuck on the tailgate. I was thinking of just building a wall and have it slide into the side walls using brackets. I just can't find any feasible options for this. I've searched Lowe's and Home Depot but can't find anything usable. If anyone has an opinion, please speak up! I've posted some pics..
What about cutting the rear posts flush on bottom so they don't go into pockets? Then use a large piano hinge to allow gate to drop down. Cables could be used to limit tailgate drop. Not to sure about latches on top but lots of gate hardware out there.
azcat is offline
post #784 of 3037 Old 08-18-2013, 02:15 PM
gouacats
John
My frame ended up being 40.5"x72". I'm actually planning on adding jschreb's military fiberglass tub eventually, so I followed his instructions:
http://tventuring.com/trailerforum/a...ad-119-31.html
I think it will be strong enough for the fire roads, mild trails that I'm planning on. I'm only planning to use it as a base camp trailer.
gouacats is offline
post #785 of 3037 Old 08-18-2013, 04:27 PM
switters88
That's another great idea. I'll have to play around with it I suppose. I post some pics with whatever I come up with. Thanks!
2012 Wrangler JKU Sport
1998 Wrangler TJ
1989 Wrangler YJ (sold)
1986 CJ-7 (sold)
switters88 is offline
post #786 of 3037 Old 08-18-2013, 11:51 PM Thread Starter
armyRN
armyRN's Avatar
Suggestion: if you're doing anything with hinges and such, don't use wood screws to attach to the boards. Use bolts that go all the way through the boards and large washers.
armyRN is offline
post #787 of 3037 Old 08-19-2013, 08:06 AM
JKBender
Originally Posted by Sahara707 View Post
Making progress. Finished the wiring, put on the diamond plate floor and loosely put up two side panels.
Complete build here:
http://www.jeepforum.com/forum/f27/a...build-1558519/
Thought I would just ask if you had an update... first metal box on this thread and all. Did you ever get the trailer all done? What do you think so fare, have you been able to use it?
JKBender is offline
post #788 of 3037 Old 08-19-2013, 09:40 AM
Sahara707
Scroll back a little and you'll see the finished pictures. I'm really happy with the way it turned out. The metal box is very solid. I haven't pulled the trailer, I've checked the lights. My receiver on my truck has a 2" ball. I have a 1 7/8" BALL for the trailer but I was waiting to get my jeep back from the shop to buy the right drop of a receiver. Now I have the new wider, 5-lug axle coming and that will change the receiver type also. There's some pictures of the new tire and rim next to the original. I Think the diamond plate steel floor will also help in the strength of the trailer frame, due to the 3/8 bolts holding it down in the corners, sides and center. Check it out. Thanks
post #789 of 3037 Old 08-19-2013, 10:15 AM Thread Starter
armyRN
armyRN's Avatar
If your diamond plate flooring is like mine, it also has some reinforcements welded underneath to give the floor extra strength. So the flooring isn't just a sheet of diamond plate like you would buy at a sheet-metal supply place.
armyRN is offline
post #790 of 3037 Old 08-20-2013, 10:34 AM
JKBender
I thought I would share this video that was made by a guy in another forum that I am a member of. This is the first video is a series that is documenting an expedition trip through Colorado. Since about half the rigs are pulling trailers (though high end ones) I thought it might be very inspiring for everyone.
In case the link gets broken:
Channel = Mark Doiron
Title = Colorado Campaign, Jul 13, Part 1
JKBender is offline
post #791 of 3037 Old 08-20-2013, 11:40 AM
Sahara707
http://www.youtube.com/watch?v=yFjr3hSzEu4
Good Video, Is part 2 on you tube? Thanks!
post #792 of 3037 Old 08-20-2013, 01:40 PM
JKBender
Not yet, but he does have a good series on his spring trip to Moab (5 or 6 videos I think).
JKBender is offline
post #793 of 3037 Old 08-20-2013, 05:13 PM
NMBruce
Mark does some great pictures & videos on the expedition modded Jeep thread
2013 JKUR sold
2006 GX470
I knew I shoulda taken that left turn at Albuquerque! - Bugs Bunny
NMBruce is offline
post #794 of 3037 Old 08-20-2013, 11:11 PM
pentaflex
There are several ways to add a tailgate. In my case, I just used a couple large hinges. And as ArmyRN suggested, be sure to use bolts (not just wood screws) to attach them. It is also important to brace it across the top if you plan to add a top and intend to go off road. Otherwise, the top will shimmy back and forth. You can see pics in post #215 and a video of mine in post #638.
P.S. I just returned after being away a while so sorry if the question has already been answered.
pentaflex is offline
post #795 of 3037 Old 08-21-2013, 06:43 AM
switters88
Thanks everybody for the replies. I found some corner brace brackets online and think I'll try these out first. If those don't line up how I like I think I'll go with the hinge at the bottom of the tailgate. I'll post some pics when complete.
1998 Wrangler TJ
1986 CJ-7 (sold)
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests)
Harbor Freight Trailer fishinjeeper General Jeep & Off-Road Equipment 14 07-21-2014 12:02 PM
Little Harbor Freight Trailer armyRN General Jeep & Off-Road Equipment 15 04-20-2011 10:03 PM
Harbor Freight Mini-mill otherwise know as Sieg X2?? MA88XJDude Fabrication Shop 13 03-29-2011 07:50 PM
Harbor Freight Trailer with AT's? Anti-bling General Jeep & Off-Road Equipment 8 12-03-2007 07:37 AM
harbor freight trailer willtjx General Jeep & Off-Road Equipment 3 05-04-2005 07:20 AM
