Mini Harbor Freight (type) Trailer Ultimate Build-Up Thread - Page 34 - JeepForum.com
 62Likes
post #496 of 3142 Old 05-11-2013, 06:36 PM
Deuskid
Originally Posted by jscherb View Post
Here's a 4x6 I just finished assembling today. It started as an HF 94564 1720-lb. capacity 4x8, and it's been modified down to 4x6, actually 40.5" x 6 because it's going under a 4x6 M416-style fiberglass tub kit (which is also why I painted it olive drab), they're 4x6 at the top and 40.5x6 at the bottom.
Making it 40.5" means the larger tires fit on the stock axle - these are 235/75-15's on Jeep 15x6 wheels. The parts left over in the process of making it smaller went into making the center backbone; at each end of the backbone is an HF receiver. The one on the front is for swapping different types of couplers, the one on the back is for bicycle carriers, etc. The rack on the front is an HF ATV Cargo Rack, the two parts are rotated 90 degrees for a perfect fit with the width of the frame.
Jeff,
Did you ever price out the cost of replacing the axle w/ a wider axle that would allow keeping the full 48" width at the frame and allow regular Jeep wheels/tires?
Would any 'engineering' effort be required or would replacing the axle be 'bolt on' easy?
Thanks,
John
Deuskid is offline
post #497 of 3142 Old 05-11-2013, 06:44 PM
jscherb
Originally Posted by Deuskid View Post
Jeff,
Thanks,
John
John,
I haven't had the need to do a wider axle because both my current military trailer project and the Jeep-tub trailer project required narrower frames than 48".
But if you wanted to keep the 48" width and do a wider axle, here's one for $112.88: http://kmtparts.com/axles-spring-mou...55-4-drop.html. You specify the hub face distance and the spring center distance and they make up the axle for you to those dimensions. The one linked to is a 2000-lb axle with a 5 on 4.5 bolt pattern (same as the HF axle, same as the TJ and YJ Wranglers). You could use the stock HF springs, and probably the u-bolts and spring plates, although that would depend on the exact diameter of the axle, they don't mention the diameter on their web site.
They also make up 3500-lb. axles for $122.99.
"Whether you think you can do something or you think you can't, you are right" - Henry Ford
jscherb is offline
post #498 of 3142 Old 05-12-2013, 06:42 AM
Deuskid
John,
Wow, that's great.
Thanks Jeff!
John
Deuskid is offline
post #499 of 3142 Old 05-12-2013, 09:36 AM Thread Starter
armyRN
armyRN's Avatar
Location: Longview, WA (one hour north of Portland, OR)
John,
John,
Be careful when ordering axles. The one linked above looks like a "dropped" axle (at least in the picture and link name) but the write-up says it's a straight axle. It threw me for a minute. Unless you're looking for a lowrider trailer, you want an axle that's straight across. If you google "utility trailer axles" you'll get plenty of hits. Make sure you order by the hubface-to-hubface measurement/width and not overall length, and to modify a famous quote: "Measure twice, order once". Once you order it (especially if they weld on the spring perches) it's yours to keep.
$112 for a 1.75" diameter axle custom length including hubs is a very good price (thanks for the link Jeff). And if a 2.375" diameter 3500lb axle was only $10 more - well that's an easy call. Plus they'll weld on the spring perches? Now it's pretty much a no-brainer. Just need to make sure there's not a size limit on tire/wheel size for the included hubs.
And very interestingly (to me anyways) on the 3500lb axle you have the option of a 5 on 5.0" bolt pattern hub (I'm pretty sure that's what the JK's bolt pattern is - you can get matching rims for your trailer).
For example, here's a 2700 lb axle (there are tons of options out there) but you still need to order hubs:
http://www.easternmarine.com/65-round-tube-straight-trailer-axle-2700-50226
Factory Jeep wheels have a deep offset. Based on some measurements I've done earlier, to run some 235/75/15" tires on Jeep factory steel rims on a 48" wide trailer you're going to need a hubface to hubface axle around 64-65" wide (of course, make sure YOU measure before ordering any axle).
Having said all that, just out of curiosity John, what's the measurement standing at the back of your Jeep JK from the center of one rear tire to the center of the other rear tire? On my TJ with 33x11.5x16" tires on 16x8 steel rims is 62". My trailer's tires center-to-center is about 51.5".
armyRN is offline
post #500 of 3142 Old 05-12-2013, 02:45 PM
jscherb
Originally Posted by armyRN View Post
John,
Actually that link is correct, it's for both a straight axle and a drop axle. The page says:
Price is for a basic Straight Idler Axle with 5 bolt hubs, non EZ Lubed.
The photo shows a drop, but the drop is a check box on the page, it's $69.55 extra.
Yes they weld on the spring perches, and it does come with hubs, it's ready to bolt on.
jscherb is offline
post #501 of 3142 Old 05-12-2013, 04:34 PM
Deuskid
thanks to you both for the additional guidance. What does it mean when they say it is 'non-EZ lubed'.
John
Deuskid is offline
post #502 of 3142 Old 05-12-2013, 05:13 PM
jscherb
John
Ez-Lube hubs have a grease fitting that lets you in theory grease the bearings using a grease gun, without removing/repacking the bearings by hand. Here's some info: http://sltrailers.com/What_are_EZ_Lube_Hubs_.html.
Some people say they aren't a substitute for periodic bearing removal/repacking by hand, but it is claimed that they can increase bearing life because you can easily and regularly ensure the hub is full of grease.
jscherb is offline
post #503 of 3142 Old 05-13-2013, 03:45 AM Thread Starter
armyRN
armyRN's Avatar
Originally Posted by BSC View Post
Added a tongue box this weekend.
Looks great!
armyRN is offline
post #504 of 3142 Old 05-13-2013, 05:55 PM
K5ADT
Start to convert my fold up trailer now. Got the bug.
Allen
K5ADT is offline
post #505 of 3142 Old 05-15-2013, 07:57 PM
greyghost79
Project "Mini Me"
This has been a great project and it is nearing completion. All I have to do is decide what I am doing with the lid. I have gone full circle from hinging at front to hinging in middle to no hinge and back to hinging at front. If I ever decide how I'm going to do it, one thing is for certain - I will cover it in black vinyl.
Attached are photos as it sits now. I do have a question for BSC -- what are you using to attach the shovel to the trailer fender? By the way, your trailer looks great!
greyghost79 is offline
post #506 of 3142 Old 05-15-2013, 08:55 PM Thread Starter
armyRN
armyRN's Avatar
I love it! It's just screaming "Adventure". And you even mounted a spare on it! Can you show a few pictures of the bike rack? Did you put a 2" receiver on the back for the rack?
armyRN is offline
post #507 of 3142 Old 05-15-2013, 09:02 PM
Mowgli25
The shovel mounts are quickfist. We use them in our fire trucks here.
Mowgli25 is offline
post #508 of 3142 Old 05-15-2013, 11:15 PM
BSC
Mowgli25 is correct I'm using quickfist, Thanks for the complement, If you don't mind could we see some photos on how you mounted the spare I still need to mount mine but I'm worried about the wood holding up on the trail.
BSC is offline
post #509 of 3142 Old 05-16-2013, 05:35 AM Thread Starter
armyRN
armyRN's Avatar
I mounted mine with a piece of metal on the inside, and a used spare tire carrier from a TJ on the other side. I have the tire resting on the trailer tongue to decrease stress on the wood. So far so good.
http://www.jeepforum.com/forum/f27/m.../#post11209803
armyRN is offline
post #510 of 3142 Old 05-16-2013, 05:15 PM
greyghost79
Its similar to armyRN's, except its a YJ spare carrier mounted thru the wood with five 1/2" bolts and large washers. I'm not planning to go offroad, but I'll keep an eye on it to make sure it doesn't bust the wood.
Currently Active Users Viewing This Thread: 17 (2 members and 15 guests)
cberrykix , Snowdogs
Harbor Freight Trailer fishinjeeper General Jeep & Off-Road Equipment 14 07-21-2014 11:02 AM
Little Harbor Freight Trailer armyRN General Jeep & Off-Road Equipment 15 04-20-2011 09:03 PM
Harbor Freight Mini-mill otherwise know as Sieg X2?? MA88XJDude Fabrication Shop 13 03-29-2011 06:50 PM
Harbor Freight Trailer with AT's? Anti-bling General Jeep & Off-Road Equipment 8 12-03-2007 06:37 AM
harbor freight trailer willtjx General Jeep & Off-Road Equipment 3 05-04-2005 06:20 AM
