Max. Flex vs. Useful Flex and The Anti-rock - Page 4 - JeepForum.com
post #46 of 117 Old 02-03-2011, 11:15 PM
rlk_99
Originally Posted by ps3tv View Post
Here's a pic:
As much as other people have recommended a front Anti-rock I would also recommend combining it with a rear Anti-rock. I drive this Jeep as a daily driver, and even with 7" of lift and 37" tires it drives fantastic.
How much body roll do you get with this set up? I need a swaybar for the rear of mine. It was taken off when the new lift was installed.
'02 Sport..... Stock no more.... RE 3.5 SF, RE adjustable trackbar(F/R) and 33x12.50x15 BFG MT's installed
rlk_99 is offline
post #47 of 117 Old 02-10-2011, 02:06 PM
Heath
2014 JK Wrangler
The spring unseating and not pushing the axle down is only half the flex story. The purpose of flex is not just traction, but to relieve weight off the front or rear so the jeep doesnt tip over one way or the other.
Heath is offline
post #48 of 117 Old 06-14-2011, 10:27 PM
muddernaught
Lupinsea & other SwayLoc'rs,
What are you running in the rear? Is the SwayLoc up front, stock in the rear, sufficient? I run 4"+ (not really sure, it was on the Jeep when I got it), 33s, and stock sways all around. I was planning on an anti rock, but find myself sold on the SwayLoc after researching and reading this thread. Just looking to tighten it up on road and loosen it up in the muck. Also need to get rid of the front sway bar to fit a bumper (don't ask ).
muddernaught is offline
post #49 of 117 Old 06-15-2011, 01:18 AM Thread Starter
lupinsea
lupinsea's Avatar
I run the stock swaybar in the rear. Both the SwayLOC and Anti-rock are designed to work with it so you'll want to keep the rear swaybar.
You mentioned the bumper clearance. Make sure the SwayLOC / Anti-rock will work with the bumper you want. Both swaybar systems stick out a few inches on either side of the frame where the front crossmember is. The bumper needs to have a "pocket" there with enough clearance. The stock bumper will work with some trimming. Savvy Offroad's bumper will work, and the ARB bull bar with (I think) some trimming, too.
- Jay
lupinsea is offline
post #50 of 117 Old 06-17-2011, 06:33 PM
muddernaught
Awesome!
Thanks for the reply and excellent information
post #51 of 117 Old 07-13-2011, 10:53 AM
jeepjones
Swayloc $875! Currie Anti-Rock $300, I'll take the Currie thank you.
jeepjones is offline
post #52 of 117 Old 07-13-2011, 11:01 AM
crgrissom
Master of Reality
crgrissom's Avatar
Agreed...and I've been very happy with my Currie AntiRock for several years now.
Chuck Grissom
Opportunity is missed by most people because it is dressed in overalls and looks like work.
- Thomas A. Edison
crgrissom is offline
post #53 of 117 Old 07-13-2011, 03:10 PM Thread Starter
lupinsea
lupinsea's Avatar
SwayLOC $500
SwayLOC $500
I don't know who's selling an $875 SwayLOC but that's nuts. The simple $500 flip-a-lever version works great and is well worth the extra $200 over the Currie in my opinion. But it's all personal preference. I like the stiffer roll resistance the SwayLOC offers for street driving.
- Jay
lupinsea is offline
post #54 of 117 Old 07-13-2011, 10:20 PM
Heath
2014 JK Wrangler
After having some serious time doing some serious wheeling on the Antirock, I am a believer and will NEVER go back to fully discod.
There were so many times on my last trip, that I would have for sure flopped if I was fully discod. Doing some wacky downhills where I had to back up and some where I had to make sharp turns. Man I have seen the light.
The ideal setup is a dual rate IMO.
image-2046631524.jpg   image-3286399092.jpg   image-2608171751.jpg   image-2573401595.jpg   image-288601251.jpg
2013 JKU Rubicon
Heath is offline
post #55 of 117 Old 07-22-2011, 08:21 PM
muddernaught
The bumper is the Metal Cloak aluminum bumper. I'm installing with the stock sway bar this weekend. Anyone installed a SwayLoc with a MC front bumper? Any trimming/adjustments necessary?
post #56 of 117 Old 08-24-2011, 10:29 PM
TallPieman
Junior Member
Ive been looking at this......
http://www.ebay.com.au/itm/310332943...84.m1423.l2649
oops posted this in wrong thread... sorry
TallPieman is offline
post #57 of 117 Old 10-21-2011, 01:27 PM
lucky-13
Do you think the SwayLOC would work with this setup (6" Skyjacker LA lift and Body Armor bumper)? The bumper bolts right in using the stock mounting holes but there are no pockets as the bumper is solid on all sides - when you say they "stick out a few inches" I assume you mean toward the front/bumper. Here's a couple of pics.
Colorado Jeep Club Member #513
05 LJ Rubicon Sahara #787 : 6" Skyjacker Longarm Lift
07 WK Overland : It's all about the Hemi : XK/WK Owners Club Member #13
lucky-13 is offline
post #58 of 117 Old 10-21-2011, 02:46 PM
IslandTJ
Both the SwayLOC and Antirock use the crossmember to pass through the torsion bar. It looks like your bumper's mount is blocking it.
Now Jeeping in Oregon
IslandTJ is offline
post #59 of 117 Old 10-21-2011, 03:28 PM
lucky-13
So does it actually pass through from one frame rail to the other or just connect to the sides (I assume there is already a torsion bar in there)? I'm wondering if some drilling/cutting in the outside of the bumper mounts would provide sufficient access without weakening the bumper mount.
BTW I'm in love with your avatar pics!
lucky-13 is offline
post #60 of 117 Old 10-21-2011, 04:06 PM
TJDaveX
Motorized toy collector
TJDaveX's Avatar
I have seen threads about issues with some aftermarket bumpers blocking the round crossmember that the Antirock and other offroad sway bars use. If I remember right, they just cut off the piece that is blocking the crossmember. I can't seem to find the thread right now for reference. The Antirock bar does live inside of that tube, and it needs to be completely open on both ends for the bushings to fit in to. I'm sure the Swayloc is the same, but I don't have one of those.
And yes, always a pleasure to see Island's avatar.
TJDaveX is offline
Flex Sambox Tires & Wheels 4 07-25-2007 10:55 PM
most flex out of a cv ? 360wrangler Engines & Drivetrain 1 07-05-2007 03:07 PM
Too much flex! mudmonkey2400 General Jeep & Off-Road Equipment 20 04-17-2007 01:03 PM
Flex; How much is really necessary? makizoo General Jeep & Off-Road Equipment 17 02-10-2005 04:15 PM
76 cj7 needs more flex jepthng1 Tires & Wheels 1 06-15-2002 06:14 PM
