Quantcast Masterflow MV50 capacity - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > General Jeep & Off-Road Equipment > Masterflow MV50 capacity
Old 07-25-2007, 10:40 PM   #1
mike481
I broke my what????
mike481's Avatar
I have a question about the capacity of the Masterflow MV50:
Attachment 34541
I am going to use the MV50 for my OBA and need to know if the specs are accurate. This is the pressure switch I want to use:
Attachment 34542
The switch comes in a couple different sizes and the one I want comes on at 110psi and off at 145psi. My question is whether or not the MV50 actually reaches the 150psi that it lists as max pressure???
If it doesnt' reach a true 150psi I can use the next size switch that comes in at 90 and out at 120psi. However, I would rather use the higher rated switch to reduce cycle time.
2000 TJ Sport
Originally Posted by bojang View Post
You could die in a horrible ball of flames, or you could make it, your call.
mike481 is offline   Reply With Quote
Old 07-25-2007, 11:06 PM   #2
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
I have one too. And in the limited use that I have had and what I have read, I think, (IMHO) it would have a hard time getting past 120 psi. I do plan to do the same thing in the future also. So keep us posted on how it turns out.
White '94 YJ 2.5L 5 speed, 33" BFGs MTs, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio
Member #94 White Jeep Club
My Jeep
'89 XJ Laredo Bone Stock
KB6NQT
Everyone is Welcome
www.rubiconramblers.com
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is offline   Reply With Quote
Old 07-31-2007, 07:02 PM   #3
Devildog985
Mike, Do you have a link where you got that switch from. Thanks, Jim
1994 YJ 5" bds Lift with M.O.R.E 5/8 boomerange shackles and BDS stretch, 1" Daystar Bl, SYE/W XJ d/shaft 8.8
YJ Nation - Big Jim Team YJ - The Revolution Begins
Devildog985 is offline   Reply With Quote
Glock Forum
