#1 | |
War Eagle
m416 trailer build
I figured i would start my very slow m416 trailer build
this is what i started with 1964 m416 1/4 ton military trailer
#2 |
War Eagle
#3 |
I have always wanted an M416. Good Luck!
#4 |
War Eagle
GOT SOME GOOD WORK DONE TODAY
PLANS NOW INCLUDE 1. NEW SHOCKS 2. NEW FLOOR 3. HAVE EVERYTHING SANDBLASTED AND PAINTED 4. CHANGE OUT HUBS TO MATCH TJ BOLT PATTERN 5. PAINT THE TRAILER TO MATCH THE JEEP 6. HAVEN'T GOTTEN THAT FAR YET SURPRISED I ONLY BROKE THREE BOLTS ON THE ENTIRE TRAILER ![]() ![]() ![]() ![]() ![]() ![]() Last edited by gixxerphil; 07-16-2009 at 03:41 PM.. |
#5 |
War Eagle
THANKS I'M GONNA NEED IT
#6 |
War Eagle
I THOUGHT OF A FEW MORE IMPROVEMENTS
1. ADD A PIECE OF ANGLE IRON SO I CAN MOUNT A JERRY CAN ON EACH SIDE(COLORED RED) 2. STOCK TJ SPARE TIRE CARRIER MOUNTED TO THE BACK 3. PIONEER RACK FROM A HUMVEE MOUNTED ON THE FRONT SO I HAVE AN AXE, SHOVEL, AND PICK ![]() ![]() |
#7 |
War Eagle
CALLED ABC TRAILER PARTS TODAY
$142.58 FOR A NEW 3500lb AXLE WITH MATCHING BOLT PATTERN SHIPPED TO MY DOOR http://abctrailerparts.com/ |
#8 | |||
Nice...
I will be doing a writeup on my M416 buildup this summer as well.
"Si Vis Pacem Para Bellum" Quote:
#9 |
i have used trailers on the 4x4 trails for many years. looks like you have some work ahead of you. consider a tail gate? it makes loading and unloading heavy gear a lot easier.
also, i have found over the years that trailer mounted jery cans should be placed behind, not in front of the trailer axle. This way as the fuel is consumed and transferred to the jeep's tank, the tongue weight will increase. otherwise, a balanced, loaded trailer, (assuming full jerry cans) will become unbalanced as the fuel is consumed. This can lead to negative tongue weight and other unpleasant things on the trail. the lunette ring will drive you crazy after a while-- consider going with a receiver tube on trailer tongue. this way you can mix and match different hitching options and for increased security, pull the trailer end hitch and add a lock pin. this makes it darn near impossible to steal that trailer. i junked the pintle/lunette set up long ago and went with the Treg hitch, which is very quiet. best of luck-- these trailers are fun, but can be a hassle on tight trails. Also, consider a receiver hitch for the rear. go to junk yard and get one from a wrecked truck. cut it down and graft into the trailer. there are many good reasons for a rear receiver on a trailer. add some shocks and bump stops and ur good to go. one of my hitches for the pack mule trailer. ![]() |
#10 |
Ditto on the Lunette hitch being noisy. Banga-banga-banga all day long with those things and they are expensive to boot.
Here is what I am using on my trailer I have under construction right now. ![]() A 3 axis hitch. The right side goes into the Jeeps Receiver and the left side is on the trailer. You can see more pics below. http://www.jeepforum.com/forum/f37/new-hitch-814792/
2006 Solar Yellow Rubicon Unlimited Jeep Club Member #1340 6 Speed, Hardtop Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come! |
#11 |
looks good! here is a pic of my scrambler w/ the pack mule ---lots still to do getting it right. Using toyota leafs and H2 wheels and 37s to match the jeep.
![]() my other trailer is a Venturecraft pop up-- it uses torsion suspension and IMO, makes it too bouncy for the trail. here's how i figured that out...LOL ![]() close up-- but w/ the 35s (long gone). also aded some hose to the tailgate chains so they don't rattle and chip of the special rattle can paint. sorry for hijack. keep the pix coming ![]() ![]() an early incarnation-- it's a lot better looking now a days. front deck is done and skinned the front w/ diamond plate. ![]() tried this but abandoned the idea. upper tower was for behind the big truck, but junked that in favor of a dropped mount to keep it all level. ![]() Last edited by RARECJ8; 07-27-2009 at 04:53 PM.. |
#12 |
War Eagle
[QUOTE=RARECJ8;7654557]i have used trailers on the 4x4 trails for many years. looks like you have some work ahead of you. consider a tail gate? it makes loading and unloading heavy gear a lot easier.
also, i have found over the years that trailer mounted jery cans should be placed behind, not in front of the trailer axle. This way as the fuel is consumed and transferred to the jeep's tank, the tongue weight will increase. otherwise, a balanced, loaded trailer, (assuming full jerry cans) will become unbalanced as the fuel is consumed. This can lead to negative tongue weight and other unpleasant things on the trail. the lunette ring will drive you crazy after a while-- consider going with a receiver tube on trailer tongue. this way you can mix and match different hitching options and for increased security, pull the trailer end hitch and add a lock pin. this makes it darn near impossible to steal that trailer. i junked the pintle/lunette set up long ago and went with the Treg hitch, which is very quiet. best of luck-- these trailers are fun, but can be a hassle on tight trails. Also, consider a receiver hitch for the rear. go to junk yard and get one from a wrecked truck. cut it down and graft into the trailer. there are many good reasons for a rear receiver on a trailer. add some shocks and bump stops and ur good to go. one of my hitches for the pack mule trailer. thanks for the input |
#13 |
War Eagle
no hijacking i like to see pics so i can steal some ideas
#14 |
I'd start by renting a sand blaster.
#15 |
War Eagle
yeah i have taken everything that bolts to the frame to my dad who is having everything sandblasted and painted out at the plant saving me a bunch of money |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
