Limited Slip Vs Lockers on Asphalt - JeepForum.com
post #1 of 3 Old 11-12-2001, 06:29 PM Thread Starter
evilpsych
evilpsych's Avatar
ok.. i'm considering putting a limited slip in my rear axle and perhaps a ez-locker in the front. I'm doing so because i'm wary of how a locker acts when exposed to slick road conditions in 2wd mode. I want to know how effective a limited slip rear/locked front works offroad and how a locked front would act in slick road conditions.. in 4wd i.e. snow/ice covered or a muddy dirt road. Also, how does a locked front act when it is disengaged from 4wd? is the steering affected at all?
A
So he wants to go OFF-ROAD does he????
'93 YJ, 4.0, K&N filter, Borla Header, Borla Cat-Back, Hi-Flo Cat, 3 Core Radiator, D-Rings, TruckNuts, MSD 6A, LockRite Locker in D30, Magnecors, Kickass Stereo, 1" daystar, 31" BFG AT's, Homemade Rocker Guards and Front/Rear air-tank bumpers with tire carrier, 15x8 AR-767 4"BS, BDS 3.5 HD lift, AMA A/C Kit, York OBA, GoFerIt 1" MML, 8,000lb HF/MM Winch, Magellan MAP 330 GPS, PRO-2067 500ch. Scanner, oh, and a CB capable of talking to SATURN!
"The Only Thing Necessary for Evil to Succeed is for Good Men to Do Nothing." - Edmund Burke
evilpsych is offline
post #2 of 3 Old 11-12-2001, 09:53 PM
bob91yj
Front locker is virtually invisible on the highway, but you may need to have your front D-shaft balanced as it will be spinning all the time now, and may cause a vibration.
I'd just save my money for a manual locker in the rear before I'd get a limited slip.
Bob
91YJ Sahara, SOA, 4.88's, 35's, Locked
bob91yj is offline
post #3 of 3 Old 11-18-2001, 04:33 PM
eltj
Locking up the front works awsome on the trail. Disengagement is not much different either. As far as the back is concered a locker is something that you learn to drive with gust like a manual or 500hp. It is a hand full on slick roads and will be a little squerlly but to be bad on the trail you make trade offs on the street. You could also have both with an ARB or OX locker. If its a tj and your locking the front I would stronly recoment the Warn front hub conversion. Your jeep will handle a little better and tires will last a little longer when disengaged while on the streets as well as having stronger components.
eltj is offline
are my lockers limited slip in 2wd? alecmcmahon Engines & Drivetrain 3 02-13-2009 09:48 AM
Lockers/Limited Slip/ Open Carriers KingofPop Engines & Drivetrain 3 02-05-2008 12:38 AM
limited slip! not. 1rockhead General Jeep & Off-Road Equipment 4 09-09-2005 02:42 PM
Limited Slip Lockers HMTwin General Jeep & Off-Road Equipment 3 02-01-2005 06:08 PM
gears/lockers?/or limited slip?? mytjnamedrex Tires & Wheels 1 09-02-2001 09:04 PM
