Light bar whistling - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > General Jeep & Off-Road Equipment > Light bar whistling
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRubicon Express Suspensions from CCOR 706-207-4140Smittybilt Hard Tops @ Oconee Off-Road! 706-534-9955
Unread 09-19-2014, 10:04 PM   #1
d_diesel27
Light bar whistling
So i installed a 50 inch light bar today and was driving down the highway and heard a very loud whistling coming from it. Has anyone had this problem and if so how have you fixed it or did you just leave it?
d_diesel27 is offline   Reply With Quote
Unread Yesterday, 05:17 AM   #2
Zeep
My "doors off" mirrors do the same thing. I have gotten used to it, not very loud.
JEEP THE AR-15 OF THE AUTOMOTIVE WORLD
Zeep is offline   Reply With Quote
Unread Yesterday, 08:38 AM   #3
mamefreak
Go to pepboys and grab some black door trim, it's like $8 for two strips, then just slide it onto the cooling fins on the back of the bar. Depending on your angle you may have to try a few times to find out which fins are the ones making the noise. Mine is silent now
mamefreak is offline   Reply With Quote
Unread Yesterday, 03:27 PM   #4
d_diesel27
Sounds like a really good idea, hopefully it works cause its so damn annoying haha. Thanks !
Unread Today, 01:23 AM   #5
1222
Make mine a Jeep!
1222's Avatar
There are two or three threads floating around on the subject, a search should pull them up. Anyhow, the weather-stripping between a few light bar fins seems to do the trick.
1222 is offline   Reply With Quote
