Lifts opinions and recommendations - JeepForum.com
post #1 of 7 Old 04-09-2014, 10:18 AM Thread Starter
rescued69
I have a Cj-5 and I'm looking to lift it 2.5 inches preferably. Looked at rough country and skyjacker. Rubicon express doesn't offer anything under 4.5. Anyone got any advice or suggestions?
rescued69 is offline
post #2 of 7 Old 04-09-2014, 11:15 AM
jp360cj
1977 CJ7
What year '5 and how much are you looking top spend? OME and BDS are probably the two most highly praised on here, although I have no personal experience with either.
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal
jp360cj is offline
post #3 of 7 Old 04-09-2014, 11:32 AM Thread Starter
rescued69
It's a 69 and preferably under a thousand. I'll spend the big bucks when I go bigger. Don't want something unreliable because I use it and plan on putting it to the test
post #4 of 7 Old 04-10-2014, 04:34 PM
tyvanwie
I don't know about them silly leaf springs, but I heard BDS is quite popular with y'all. I have their 2" coil lift on my TJ. Good quality for the price IMO.
tyvanwie is offline
post #5 of 7 Old 04-10-2014, 11:38 PM
jp360cj
1977 CJ7
Your 69 uses different leaf springs and a different style shackle than the 76 and newer. I really don't know much of anything about the lifts available for the early '5s.
Are you wanting to convert to a later CJ setup? Not sure what all would be involved in that for you. You can also check on a YJ spring conversion. Rear is pretty much the same as a late CJ but front springs are wider and longer. Haven't done the swap personally, but everyone on here who has swears by it.
jp360cj is offline
post #6 of 7 Old 04-11-2014, 10:34 AM
strvger01
1966 CJ5
for only 2" or so, you could just go with a body lift while you plan your larger suspension lift. i've used those for years with no issues. also gives you a chance to replace the 40+ year old body mounts and that should help with the ride.
1966 CJ5A, mods are coming
1966 Wagoneer, bone stock
strvger01 is offline
post #7 of 7 Old 04-13-2014, 04:30 PM
NonRubicon
There isn't much love for the low budget lifts like Rough Country here on Jeepforum. Poor fit, rough ride, premature sagging.
If your max budget is $1000 for a 2.5" lift, you may want to look into a 2.5" lift from BDS suspension.
NonRubicon is offline
