Lift kits vs body lift - JeepForum.com
post #1 of 19 Old 09-02-2013, 05:32 PM Thread Starter
Wraven
Hello everyone
I'm new to this jeep life and could use some help.
I'm not a off road guy but I do want to add bigger tires 34 or 35's. I'm just not sure if I should just do a body lift or suspension lift.
If I do a SL I really don't want to change other components. I just really like the look of a jeep with bigger tires.
Not sure how to go here.....
Wraven is offline
post #2 of 19 Old 09-02-2013, 05:37 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Just use a sawzall, you don't have to do anything to fix drivelines or brake lines. No pesky suspension travel or control arm talk. Just cut and run. Literally.
Luck Favours The Prepared
Anticanman is offline
post #3 of 19 Old 09-02-2013, 05:38 PM
Kodiak17
35's really aren't worth your time if you're going for just aesthetic appeal. I'd suggest 33's at the most.
Maintain, wheel, upgrade, repeat.
My build: http://www.jeepforum.com/forum/f22/thor-dd-weekend-warrior-1348534/
Kodiak17 is offline
post #4 of 19 Old 09-02-2013, 07:21 PM
Lincolnwelding
Yeah i wouldnt go 35's just for looks. I would suggest a 2 inch suspension lift and 33 inch tires. Maybe put wheel spacers on since you wont be doing any offroading. With 2 inches of lift i dont think you would run into any problems. But im not an expert.
"Piper, theres a big difference between wingin it, and seeing what happens"
Want to change my forum name to jeep wheelikers
WJC #292
Lincolnwelding is offline
post #5 of 19 Old 09-03-2013, 06:45 AM Thread Starter
Wraven
I was actually thinking of doing a 2.5 suspension lift. Adding 33' tires would look really good I think.
Wraven is offline
post #6 of 19 Old 09-03-2013, 06:49 AM
SLADE
A small body lift works very well with a suspension lift on both the street and the trail.
2014 Wrangler JKU
2013 Wrangler JK
2004 Wrangler TJ on LEAFS
2001 Dodge Ram 2500
SLADE is offline
post #7 of 19 Old 09-03-2013, 07:06 AM Thread Starter
Wraven
I was thinking of doing a 1' body lift and a 2 or 2.5' suspension lift as well
Wraven is offline
post #8 of 19 Old 09-03-2013, 11:47 AM
ancientspear
Isn't that basically a tummy tuck without doing the best part, moving your guts higher?
ancientspear is offline
post #9 of 19 Old 09-03-2013, 04:59 PM Thread Starter
Wraven
I really would rather not move the guts around. Lol. I'm all about the look. Hehe
Wraven is offline
post #10 of 19 Old 09-03-2013, 08:15 PM
GilaMtnJeep
GilaMtnJeep's Avatar
A 1" BL and a 2-1/2" suspension lift would give plenty of room for 33's. Read up on lifts. Don't know what your budget is but if you can go with a springs/shocks kit over a budget boost. It will ride and handle much better. Also, if your gonna go with 12.5 wide tires you may need 1-1/4" wheel spacers so you don't rub at full steering lock. I'm not sure if a 1" BL will also require a 1" MML.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
post #11 of 19 Old 09-03-2013, 08:28 PM
SLADE
The MML is not required with the BL. The fan shroud can be lowered to avoid lifting the motor.
The MML is a good addition to the BL though. The MML will allow you to avoid moving the fan shroud, will raise the oil pan up another 1", and will improve the rear driveshaft angle. You'll also be one step closer to a flatter skid.
2014 Wrangler JKU
2013 Wrangler JK
2001 Dodge Ram 2500
SLADE is offline
post #12 of 19 Old 09-03-2013, 09:22 PM Thread Starter
Wraven
What's a MML? Lol
Wraven is offline
post #13 of 19 Old 09-03-2013, 09:46 PM
tjcj
Originally Posted by Wraven View Post
What's a MML? Lol
MML = Motor mount lift
Sent from my XT881freeze ray gun using JeepForum
Yakima Valley Mountaineers.
tjcj is offline
post #14 of 19 Old 09-06-2013, 07:53 AM
CaptLeeB
If the OP is not interested in going off road the MML is a waste of $. Also there will be no need in a flat skid/tummy tuck.
If your going for aesthetics. Like everyone else said, 2-2.5" lift and 1" body for 33's.
CaptLeeB is offline
post #15 of 19 Old 09-06-2013, 09:05 PM
SLADE
An improved rear driveshaft angle is not a waste of money and will benefit even a street driven Jeep.
2014 Wrangler JKU
2013 Wrangler JK
2001 Dodge Ram 2500
SLADE is offline
