Lift issue - JeepForum.com
post #1 of 7 Old 03-28-2013, 07:03 AM Thread Starter
icrawltn
Lift issue
I just installed a rough country 4" lift on my 2000 tj and everything is done correctly on the front this isn't my first lift I've installed but for some reason measuring from the floor up to the bottom of the fender on the front under the turn signal the driver side is 34 1/2 and the passenger side is 33 1/4 what could this be ?
icrawltn is offline
post #2 of 7 Old 03-28-2013, 11:50 AM
1320quick
Different length or rate on the springs installed on each side? I would double check to make sure each spring is seated correctly on the top and bottom.
1320quick is offline
post #3 of 7 Old 03-28-2013, 02:05 PM
dr hook
maybe the spring isolator on top of one spring is missing?
Lifted ZJ with stuff.
dr hook is offline
post #4 of 7 Old 03-28-2013, 07:38 PM Thread Starter
icrawltn
Isolators are still on both sides.... Springs are seated on top and bottom that was what I checked first.
icrawltn is offline
post #5 of 7 Old 03-29-2013, 06:56 AM
tyvanwie
It's RC. I've heard it happening to a few people.
Sent from my iForum using JeepPhone
tyvanwie is offline
post #6 of 7 Old 03-29-2013, 09:07 AM
eduardostewart
that might explain why my right rear seems to be off a smidge. bought my tj with it on, i can say whenever i'm able to upgrade, it won't be RC
eduardostewart is offline
post #7 of 7 Old 03-29-2013, 02:11 PM
1320quick
How about swapping the front springs? Move the left spring to the right side and right to the left. Then measure again and see if the problem follows the springs or stays on the original side.
