Lift height - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > General Jeep & Off-Road Equipment > Lift height
Yukon Ultimate 35 axle kit for c/clip axles with Yukon ZipSome Free shipping Coupon codesSPARTAN LOCKERS are on sale BIG TIME at ROCKRIDGE 4WD!
Unread 02-27-2015, 06:02 PM   #1
Zyurazek
Lift height
Alright, so I am trying to decide on a few things for my YJ but I can't make a decision before I figure out what size lift I have on this. I know it's lifted, and it has about a 1.5-2 inch transfer case drop. I put new shock on it about a year ago. Based off the shocks I pulled off, I used the part number and it showed that they are used for 2.5-3 inch lifts. I have no idea if the shocks are correctly sized though. I'm riding with 32s but it seems like there's more space than what there should be if 2.5-3 inches of lift was installed.
Here's a couple pictures I took when I stripped it down to have painted.
Any ideas?
Zyurazek is offline   Reply With Quote Quick reply to this message
Unread 02-28-2015, 12:07 PM   #2
wheelin
3 to 4 inch lift
95 yj
wheelin is offline   Reply With Quote Quick reply to this message
Unread 02-28-2015, 12:10 PM   #3
Anticanman
Follow me
Anticanman's Avatar
Get a measurement to the bottom of the rocker panels. Stock is 18" on 29" tires. Half an inch for every inch of tire you're running then subtract 18
Luck Favours The Prepared
Originally Posted by Opihi59 View Post
Enabler!!!!, Heretic!!!! This is denial. It's not part of the 12 step process. "Hi, my name is Ian, and I hate Torx." Hello brother Ian. Friends don't let friends use Torx bolts. Just mail them out to me, and I'll drop them in the volcano and let Pele take care of them.
I Hate Torx
Anticanman is offline   Reply With Quote Quick reply to this message
Unread 03-01-2015, 11:15 AM   #4
Zyurazek
Originally Posted by wheelin
3 to 4 inch lift
3 to 4 inch lift
I believe you are right.
The old shocks I pulled off were made from skyjacker. So I just read up on one of their lift kit manuals and it showed that if there was a 4" kit installed, a track bar expansion bracket that comes with the kit should be installed. On the other lower kits by skyjacker, these brackets were not supplied. So based off of that, I have to believe I have a 4" lift. I will confirm by measuring ground to rocker clearance.
I guess I now should replace my struts to match a 4" lift, not a 2.5-3" lift.
Unread 03-02-2015, 08:32 PM   #5
billiebob
Definitely a 3-4 inch lift.
You are used Front Wheel Drive???? replacing struts?
Nice paint, nice driver too.
My Uncles first Jeep was a Government Issued Jeep in 1944.
Back when ALL Jeeps were Government Issued.
billiebob is offline   Reply With Quote Quick reply to this message
Unread 03-02-2015, 09:44 PM   #6
Zyurazek
Originally Posted by billiebob
Definitely a 3-4 inch lift. You are used Front Wheel Drive???? replacing struts? Nice paint, nice driver too.
I have no idea why I called it a strut. I guess I had been doing so much reading on shocks and struts that the term slipped my mind.
Thanks! And that's my mother driving. I couldn't trust her driving my rental that I had while the jeep was being painted.
She's single!
