LED lightbar / relay question - JeepForum.com
post #1 of 4 Old 01-18-2014, 10:01 PM Thread Starter
ronlunn
I am getting ready to mount a few LED light bars to my Jeep. Do LEDs draw a low enough amount of power to wire without relay, or do they require a relay in the installation? I am planning on running a relay for each one, but I wanted to make sure. The switches I am planning on using are all 30 amp.
Thanks!
2008 Jeep Wrangler Unlimited
2006 Jeep Wrangler Golden Eagle
2006 Jeep Wrangler Unlimited
ronlunn is offline
post #2 of 4 Old 01-19-2014, 08:43 AM
Indy
Indy's Avatar
Yes no maybe.
I want to move 30k pounds. Will an engine do that? Yes if its a big diesel, no if its a lawnmower engine, maybe without any more info.
So long way of saying, how many amps are the led's youre using draw?
I'm the only gay eskimo.
Indy is offline
post #3 of 4 Old 01-20-2014, 05:54 PM Thread Starter
ronlunn
Good point - it is a 120W bar so I believe that means it will draw about 10 amps.
ronlunn is offline
post #4 of 4 Old 01-20-2014, 08:29 PM
Demp
The math is correct, considering 12v. They may be 120W at 14v but that would lower current, better on the safe side.
You could run 10a through a 30a switch, I would use relays just out of habit.
Demp is offline
