Key won't manually unlock door but starts jeep - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > General Jeep & Off-Road Equipment > Key won't manually unlock door but starts jeep
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 06-06-2014, 03:25 PM   #1
robk428
Hello,
I recently purchased a 2005 Jeep Grand Cherokee (finally had to retire the 97 Grand Cherokee). However, I was given 1 key for it. The buttons on the key work to lock/unlock and the key starts the Jeep BUT when I manually put the key in the door to unlock, it doesn't turn the lock.
There isn't another lock on the Jeep so I am limited on troubleshooting this. Either the lock in the door is bad or the key is bad. I have a hard time believing the key is bad though because it starts the Jeep without a problem.
Any thoughts on how I should proceed?
Thanks,
Bob
robk428 is offline   Reply With Quote Quick reply to this message
Unread 06-06-2014, 03:36 PM   #2
TJCrawling
TJCrawling's Avatar
My TJ did that this winter, thought key cylinder was frozen. Thawed it out in a heated garage and still had the problem until I squirted WD-40 into the key hole and worked the key back and forth a little. Has been fine since and works smoother than I ever remember.
TJCrawling is offline   Reply With Quote Quick reply to this message
Unread 06-06-2014, 03:45 PM   #3
robk428
Thanks, I will give it a shot when I get home!
Unread 06-06-2014, 04:57 PM   #4
robk428
No luck. Any other ideas?
Unread 06-06-2014, 05:59 PM   #5
TJCrawling
TJCrawling's Avatar
May just have worn tumblers at this point and have to have it re-keyed, does the key work on the passenger door?
Unread 06-07-2014, 10:00 AM   #6
robk428
There isn't another lock on the jeep I can try. Nothing on the passenger side or lift gate. Do I have to go to a dealer for the tumbler or can any locksmith fix it?
Unread 06-07-2014, 01:06 PM   #7
Vin
I had a key cut for my JK, and the ;ock smith cut it too deep. It started the Jeep fine, but won't open the doors. It could be the key. Just take it to a lockmith, and have a new key made from code (Use your VIN). If the new key still doesn't open the door, the you know the lock is bad. You really should have 2 keys anyways.
Vin is offline   Reply With Quote Quick reply to this message
Unread 06-07-2014, 03:18 PM   #8
TJCrawling
TJCrawling's Avatar
Like Vin said, good cheap way to diagnose the problem. Used to know a locksmith and watched him replace tumblers once and it looked pretty simple, probably not that expensive either. Tell the Locksmith the problem and he may be able to cut to the chase and fix it right away. Dont think you need to visit a dealer for this.
Unread 06-09-2014, 05:28 AM   #9
robk428
Thanks for the responses. I will call the locksmith today.
Unread 06-22-2014, 09:07 PM   #10
sean_haynes
I hope you figured it out. I'm having the same exact issue in my 2000 wj.
sean_haynes is offline   Reply With Quote Quick reply to this message
