Jeep "Chugs"/shakes at 2000 rpm - JeepForum.com
post #1 of 7 Old 06-02-2013, 03:53 PM Thread Starter
usmc1354
i have a 2001 jeep wrangler that chugs at 2000 rpm. it has in every gear, but if you go below or above 2000 rpm it doesnt happen. why might this happen?
usmc1354 is offline
post #2 of 7 Old 06-02-2013, 09:13 PM
Patman8354
I am curious to see if anyone else has a solution for this. My '99 Wrangler has a flat spot in the acceleration from like 1900 to 2100. Sounds similar to your problem maybe.
Patman8354 is offline
post #3 of 7 Old 06-04-2013, 09:13 AM Thread Starter
usmc1354
does anyone know?
usmc1354 is offline
post #4 of 7 Old 06-06-2013, 09:36 AM
Patman8354
I put an o2 sensor and a tps in mine and haven't had a problem in a few days
post #5 of 7 Old 04-19-2017, 01:59 PM
lowerybw
Did you ever solve this issue? What was cause?
lowerybw is offline
post #6 of 7 Old 04-20-2017, 12:14 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
The OP hasn't been in the forum in three years so it's not likely he'll be able to answer your question. Are you having a similar sounding issue?
Jerry Bransford is offline
post #7 of 7 Old 04-21-2017, 08:46 AM
lowerybw
Yes, Chuggs and shakes at 2K RPM. Above or below it is fine. I changed the TPS sensor and both O2 sensors like suggested above and it still does it.
lowerybw is offline
