Quantcast Interior insulation for the floorboards - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > General Jeep & Off-Road Equipment > Interior insulation for the floorboards
GR8TOPS Introduces the Exogate HD Tire CarrierThe Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!
Old 11-15-2008, 09:47 PM   #1
wwhitby
1979 CJ5
I just have the rubber floor liner in my '79 CJ-5, so it tends to get pretty warm in the cabin in both the summer and winter because of the heat coming off the engine, tranny, exhaust, etc
I've looked around for insulation to put down under the floor liner, but all I can find is the kind that it meant to be either glued or taped down. I want something that is removable for cleaning out the Jeep and when I need to do work on it.
Does anyone know of any type of insulation "blanket" (for lack of a better word) that I can put down under the rubber floor liner and will be removable?
Thanks,
Warren
Warren Whitby
1979 CJ-5 "Big Blue"
Real Jeeps have rust
Just Empty Every Pocket
wwhitby is offline   Reply With Quote
Old 11-17-2008, 09:15 AM   #2
mylt1
just use the normal stuff with either Velcro or some double sided tape in small sections like the floor pan under your feet and at the edges so it doesnt shift. you dont "have" to glue it down. if you dont want to do that, just lay it in there for a while. if it shifts around then secure it in some way.
mylt1 is offline   Reply With Quote
Old 11-17-2008, 10:02 AM   #3
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
Get yourself a Summit Racing catalog from www.summitracing.com/ and you'll find probably a dozen different types of insulation products meant for that purpose, most having an aluminum coating on both sides. They not only keep the heat out, they help keep out road noise too. I think JC Whitney's catalog may also have similar products as well but I'd recommend Summit Racing for faster shipping.
Gone to King of the Hammers, back Sunday!
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Glock Forum
