Interest in a folding hitch mounted tire carrier? - JeepForum.com
post #1 of 22 Old 04-13-2012, 08:46 AM Thread Starter
Azzy
Im working on a hitch mounted tire carrier for class 3 hitches that holds a tire and folds straight down.
It would have a clevis for a d-ring so the utility would not be lost, and a mechanism to fold it back up, so most could do it one handed.
Im planning on doing to for up to 35" tires, maybe more.
What interest would there be, and what features would people like to see?
Im the guy who makes new gauges, check out our gallery at Teamadw.com
Azzy is offline
post #2 of 22 Old 04-13-2012, 10:57 AM
unlblkrubi
http://media.photobucket.com/image/H...arrier/TC7.jpg
Black 13 JKUR 10th Annivsary
White 13 JKUR
___________________________________________
unlblkrubi is offline
post #3 of 22 Old 04-13-2012, 11:08 AM Thread Starter
Azzy
Originally Posted by unlblkrubi View Post
Anything to add to that?
Yes, I know they have been done on a one off basis, but I have yet to see anyone take into account the issues with lifting a loaded one up and down. Also yet to see a commercial one.
Ive got to add.. one issue with a design like that is you start surpassing the rating of the hitch when you put more weight out further. So in order to open a hatch, you would have to pull jerry cans and a high lift off, unless you had a very light weight tire and rim on the carrier.
IIRC, about 3' out you need to keep the weight under 150lbs.
Azzy is offline
post #4 of 22 Old 04-13-2012, 12:33 PM
jbg1980
I think it would be cool if it folded down to use as a table,small work bench, or seat.
99XJ,4.0,AW4,NP242,D30,D35,3.55,& 30X9.50R15 BFG AT
jbg1980 is offline
post #5 of 22 Old 04-13-2012, 12:44 PM Thread Starter
Azzy
I thought that as well. In that case, one could add small legs to it to make sure it didnt exceed the weight limits one down.
A pair of seats with a little table on the center I think would make for a perfect tailgate experience in an XJ, even in a light rain.
Azzy is offline
post #6 of 22 Old 04-13-2012, 12:50 PM
jbg1980
A place to set a small stove on and bbg some hotdogs would be nice for lunch out on the trail. The legs would be a good idea with quick attachment points. Sale a base version, and then accessories that attach to it? What would you use to keep the assembly from rattling in the receiver hitch ?
jbg1980 is offline
post #7 of 22 Old 04-13-2012, 12:58 PM
Erik719
1983 CJ7
I would be interesed.
BTW, I saw something like this offered commerically for HMMWVs about 6 or 8 years ago.
'80 CJ7 - Gone but not forgotten
'83 CJ7 - Donkey
Erik719 is offline
post #8 of 22 Old 04-13-2012, 01:12 PM Thread Starter
Azzy
Ive found a swing out one, but it runs as much as adding one onto most of the aftermarket bumpers, in the $700 range
If you can recall it, I would be up for buying one, and making sure Im not infringing on anything. Going to have to build one first to work out the kinks, right?
Azzy is offline
post #9 of 22 Old 04-13-2012, 01:19 PM
jbg1980
Better get building
jbg1980 is offline
post #10 of 22 Old 04-13-2012, 01:35 PM
unlblkrubi
White 13 JKUR
post #11 of 22 Old 04-13-2012, 01:36 PM
unlblkrubi
http://www.jeepforum.com/forum/f12/r...arrier-941022/
White 13 JKUR
post #12 of 22 Old 04-13-2012, 01:55 PM Thread Starter
Azzy
Yep, seen those too. Honestly, thats where I got the idea. Are you posting to add ideas, posting to say its been done, or???
Cause you havent said a word
Azzy is offline
post #13 of 22 Old 04-13-2012, 03:19 PM
unlblkrubi
Just ideas, I'de like to see a way to pick up a 35' tire easily. Always thought it was a good idea.
White 13 JKUR
post #14 of 22 Old 04-13-2012, 04:52 PM Thread Starter
Azzy
Its going to take some math and some bits and pieces... Need to find someone to weigh a 35 or 4.
Azzy is offline
post #15 of 22 Old 04-13-2012, 07:46 PM
ryan6580
Great idea but how much approach angle would you give up? I hit my receiver now and it only sticks out 4 inches.
ryan6580 is offline
SWAG tailgate and tub mounted tire carrier AstroZombie Fabrication Shop 20 08-12-2014 07:11 AM
Hitch Tire Carrier Cargo carrier HELP :D Madmanmiller802 Fabrication Shop 32 03-11-2011 07:04 PM
receiver mounted tire carrier - my take CJ7Pilot Fabrication Shop 28 02-04-2011 01:59 PM
Solution for a loose, hitch mounted cargo carrier NonRubicon Cheap Tricks & Fixes 7 11-22-2010 08:37 AM
curt hitch mounted tire carrier aircruiser Cheap Tricks & Fixes 2 09-15-2009 02:55 PM
