Increasing Gas Mileage - Page 2 - JeepForum.com
post #16 of 22 Old 03-14-2011, 04:22 PM
work4mud
Sure fire way to make your tank of gas last longer....drive your jeep less often.
FOR SALE: 2003 Jeep Wrangler X. 4.0L I6 with 38k original miles, Auto trans, 4" suspension 1" body lift, 35x12.50r15 BF Goodrich KM2's. Hard Top, Full Doors, fullsize spare tons more to list.
work4mud is offline
post #17 of 22 Old 03-17-2011, 07:28 AM
grininmonkey
Meat Popsicle Stick
grininmonkey's Avatar
I have just recently found that having equal tire pressure in all 4, correct wheel alignment and correct rear drive shaft angle shot me up from 14.2 mpg on average of 18.7 mpg (city + highway).
I had a some what noticeable vibes with a budget lift and an at home alignment until recently, where I put in new coils,shocks and lowered my transfer case to correct my drive line... then I caved in and had a shop set my toe-in to 13 or basically between 0 and 1/8" toe-in.
The entire driving experience was very noticeable and it was apparent that I had bad drive line conditions and alignment that was causing my engine to work a little harder than it should have been :-)
grininmonkey is offline
post #18 of 22 Old 03-17-2011, 08:30 AM
duffer
1955 CJ3B
18 isn't bad and I doubt any tuning with that new a vehicle will really gain much. A tire change can make a difference:
http://www.fourwheeler.com/techartic...omy/index.html
duffer is offline
post #19 of 22 Old 05-18-2011, 05:13 AM
guruleenyc
Do these throttle body spacers work as advertised by claiming 1-4 miles additional per gallon, which are also reviewed on these major 4x4 sites...?
Ordered one at Advanced, not sure if I will follow through....
Please advise fellow enthusiasts.
guruleenyc is offline
post #20 of 22 Old 05-18-2011, 05:15 AM
D3f4ult
TBS and CAI are very arguable about there improvements, if any.
I will say I change my spark plugs after 60k (the PO never did it) for $15 and 20 minutes in the parking lot and I went from 15mpg to 17mpg.
D3f4ult is offline
post #21 of 22 Old 05-18-2011, 08:18 AM
Stinkbug
Stinkbug's Avatar
According to the manufacturer's website these should do the trick (If it wasn't true they couldn't put it on the internet).
"Airtabs™ are patented, unique wishbone shaped vortex generators designed to increase vehicle aerodynamic performance and fuel economy by reducing aerodynamic pressure drag at two key locations..."
Unfortunately, one of those "key locations" is most likely your wallet. Thinner wallet = less weight and drag.
Stinkbug is offline
post #22 of 22 Old 05-18-2011, 08:38 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
No, absolutely not. They do nothing when under the air-only type of throttle body modern Jeeps come with. Spacers can help when installed under carburetors and the older no-longer used throttle body injection (TBI) throttle bodies but a spacer will do absolutely nothing when under the TJ's type of throttle body.
Don't bother picking up the spacer when it comes in. If you already paid for it, cancel the order so you don't waste your $$$. Really.
Gone on vacation until August 25.
Jerry Bransford is offline
increasing headunit radio reception lancer27 Audio, CB & Ham Radios, GPS, & Electrical 7 11-29-2009 03:23 AM
Increasing tire/wheel width without rub? DocJake Tires & Wheels 1 10-07-2009 01:27 PM
Head Unit Resets Repeatedly When Increasing Volume bigbarr Audio, CB & Ham Radios, GPS, & Electrical 12 07-03-2009 08:53 PM
Increasing FM radio reception, Tips? poweredbysoul Audio, CB & Ham Radios, GPS, & Electrical 2 06-05-2008 01:02 PM
Increasing driveline vibes kingvm Tires & Wheels 2 01-17-2006 12:03 PM
