Increasing Gas Mileage - JeepForum.com
post #1 of 22 Old 03-09-2011, 04:41 PM Thread Starter
1ststater
I have a 2008 (bought new 9/07) Sahara loaded - added 2"lift and K/N air intake , has 90k miles...all highway. Any quality info on increasing the mpg. I'm getting on avg 18 mpg.
Thanks!
1ststater is offline
post #2 of 22 Old 03-09-2011, 04:43 PM
bds5
Wish I was getting 18mpg.
bds5 is offline
post #3 of 22 Old 03-09-2011, 04:46 PM
2005X
Thanks!
did you add the sticker with your K&N? that may be your problem
2005X is offline
post #4 of 22 Old 03-09-2011, 06:47 PM
vt98xj
+1, you are diving a jeep not a honda civic. They get bad gas mileage.
98 XJ 4.5" lift, 4.0 .030 over mopar cam
06 VW Jetta GLI
SOLD-92 S-10 350 V-8 th400 street truck
vt98xj is offline
post #5 of 22 Old 03-09-2011, 08:05 PM
Just_Jking
18... you should be ecstatic.. I get 15.5 and if the wind is behind me 16.5
Just_Jking is offline
post #6 of 22 Old 03-09-2011, 09:41 PM
Troller1234
Try coil spacers on the rear springs, that way you are always going down hill.
Troller1234 is offline
post #7 of 22 Old 03-12-2011, 09:02 PM
My1989Jeep
1989 XJ Cherokee
Tune up, spark plug wires, symthetic oil, and proper tire pressure.
1st 1989 Jeep Cherokee Laredo. 4 Door. Automatic. 4.0L Straight Six.
My1989Jeep is offline
post #8 of 22 Old 03-13-2011, 04:45 PM
chadsmeltzer
chadsmeltzer's Avatar
EPA says 08 JK gets 15 city 19 highway, I would say your 18 average is nothing to complain about at all.
04 TJ - 2 KC Daylighters, 35x12.5x15 MT/R Kevlar, 3" coils, Rear 4 link, 1.25" JKS BL, 1" JKS BMML, 33 Eng. Hi-Clearance Skid, 8.8 with LS, D30 EZ locker, OBA
chadsmeltzer is offline
post #9 of 22 Old 03-13-2011, 04:47 PM
LJameson
Do what I did and buy a Focus. Then you'll get 35 mpg
1990 YJ
LJameson is offline
post #10 of 22 Old 03-13-2011, 04:55 PM
fishinjeeper
X2. 18 is good. maybe just a tune up and new o2 sensors might get you to 20 a gallon
01 TJ. 35 inch KM2's. 4.5 RE. 2 inch body lift. dana 44. Detroit Locker. Olive Drab!! all set for trout and bambi!
fishinjeeper is offline
post #11 of 22 Old 03-13-2011, 05:01 PM
wheels082
2010 JK Wrangler
As previously mentioned, I would also recommend changing all the fluids to a quality synthetic such as Amsoil. It is not a huge difference, but every little bit helps.
wheels082 is offline
post #12 of 22 Old 03-14-2011, 07:58 AM
zerocool333
Yeah 18mpg is really good. We have a lot of hills here but I was able to squeeze out 17mpg (city) in my 4.0. Tune ups help as well as correct tire pressure helps. For me, driving like a granny and trying hard to keep the RPMs below 2k helped the most.
zerocool333 is offline
post #13 of 22 Old 03-14-2011, 08:48 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
X2 nothing being around that is going to improve your MPG. Certainly that K&N isn't helping to do anything but allow more fine dust, silica, dirt, etc. into your engine. That's about the worst air filter there is for actually filtering dirt out of the air. They don't add any performance or mpg benefits to the TJ whatsoever, despite their marketing hype.
Jerry Bransford is offline
post #14 of 22 Old 03-14-2011, 01:28 PM
imlikeojnow
I got rid of my bronco that got 11 miles to the gallon for the jeep with 4.56 33s 3 inches of lift, and i get right at 18 and that is all city driving. havent figured highway yet. i cant complain really.
imlikeojnow is offline
post #15 of 22 Old 03-14-2011, 01:59 PM
Cards81fan
Cards81fan's Avatar
2005 KJ Liberty
Aside from what everyone listed, which basically says you are already doing very well, you can get an all-season or highway tread tire in a lower weight and narrow tread width. Of course, the less aggressive the tire the worse it will perform off-road. So caveat emptor
Also drive as gingerly as possible. If you really want to know how easy you are driving, you can install a vacuum gauge and try to drive keeping as much vacuum as you can. Generally, the higher the vacuum the less fuel/air you are using, and the better the mileage.
Mindset, skillset, toolset - in that order!
Cards81fan is offline
increasing headunit radio reception lancer27 Audio, CB & Ham Radios, GPS, & Electrical 7 11-29-2009 03:23 AM
Increasing tire/wheel width without rub? DocJake Tires & Wheels 1 10-07-2009 01:27 PM
Head Unit Resets Repeatedly When Increasing Volume bigbarr Audio, CB & Ham Radios, GPS, & Electrical 12 07-03-2009 08:53 PM
Increasing FM radio reception, Tips? poweredbysoul Audio, CB & Ham Radios, GPS, & Electrical 2 06-05-2008 01:02 PM
Increasing driveline vibes kingvm Tires & Wheels 2 01-17-2006 12:03 PM
