How To Use A Winch With No Trees Around ?? - Page 2 - JeepForum.com
post #16 of 29 Old 07-20-2011, 07:40 PM
danielbuck
1946 CJ2
wonder if there's an elegant way to remove them with the winch?
danielbuck is offline
post #17 of 29 Old 07-20-2011, 08:03 PM
Benderff
Benderff's Avatar
Originally Posted by txsjp View Post
Even though it seems a lot of guys on here don't like hi-lifts you could use it to remove the pickets if they have a top.
That is a good idea. I always seem to beat them out.
Yes, but I think it ends with the picket in the front window.
Benderff is offline
post #18 of 29 Old 07-20-2011, 08:47 PM
TJamie
Originally Posted by Benderff
Pulling them out when you are done can be a pain.
Good reason to carry a hi-lift jack.
TJamie is offline
post #19 of 29 Old 07-20-2011, 10:40 PM
Benderff
Benderff's Avatar
Yes, but i'd rather beat it out.
Sent from my iPhone
Benderff is offline
post #20 of 29 Old 07-22-2011, 02:04 PM
twitchnljeep
[QUOTE=neatocj;11889668]a big big fat girl... but I mean immense!
wouldn't this option require that you not wheel alone?!? as she needs a way to get out there well i guess she can keep your buddy's jeep from moving while you anchor to him!
twitchnljeep is offline
post #21 of 29 Old 07-23-2011, 03:05 PM
hammerz71
We had a guy from a local 4x4 shop demo a Pull Pal at our hunting club maybe 4 or 5 years ago, it worked well. Was able to pull a pretty heavy Ram CTD off a sand bar at the river. If it could hold with that vehicle it should be a snap for any Jeep product...
2002 Jeep Grand Cherokee Overland
Old Man Emu HD coils, 265/65/17 Nitto Terra Grapplers, Warn M8000, home made light bar, Cepek 130 watt lights, Hella 500s
CURRENTLY REBUILDING THE 4.7 HO ENGINE
hammerz71 is offline
post #22 of 29 Old 07-23-2011, 03:47 PM
OldCJ
1978 CJ5
I've heard of some people using a large chunk of chain with rebar driven through the links at an angle, but I've never tried it.
OldCJ is offline
post #23 of 29 Old 07-23-2011, 10:59 PM
alittleoff
When I got my Pull-Pal, I used it once to become familiar with it. Simple and effective. I've buried my spare tire, simple, effective and labor intensive, but that was 30+ years ago. And I still use my Hi-Lift jack to this day to change a flat or stuff rocks in a hole. There is a lot about wheeling alone that I like, although self preservation is higher on the list. Ergo the 12 ga. & 9mm hollow points. Think smart & be alert.
alittleoff is offline
post #24 of 29 Old 07-24-2011, 06:31 AM
little_Jeep
Wheel-n alone just isn't a good idea... A few months ago, I was leading a group down a steep incline, about half way down the trail makes a very sharp left turn (WTF?), anyway, the turn itself wasn't the problem, it was a washed out hole in the turn that was... my left front tire fell into this hole, and my right rear came about 3 foot in the air. At that moment, moving my body made the Jeep move, no way for me to safely even get out of the Jeep much less do anything to keep it from going over the hill. If I had been wheel-n alone, I guess sooner or later, someone would have found my body.
little_Jeep is offline
post #25 of 29 Old 07-24-2011, 04:22 PM
billzcat1
Chicken in a Turkey Suit
2003 WJ
I think a Danforth-style marine anchor would work really well. Good strength-to-weight ratio, bulky, but you could keep it on a roof rack.
~Richard
billzcat1 is offline
post #26 of 29 Old 07-27-2011, 11:20 PM
Keojoe1981
You can bury the end into the sand and then have a monster from the movie "TREMORS" bite down on it and sliver and bury in the opposite direction. I am only kidding, you can either get a pully system..no no no no no no no no no no no no no, wait.... oh yeah have one of your friends go with you.. No really I am only playing... if all else fails you can get a REEEEAAAAALLLLLYYYY LOOOOOOONNNNNNGGGGGG cable that will reach a tree of some sort.... OR you can just take a heavy duty 4-5 foot stake and hammer it down at a 45 degree angle away from you and hook the end to the bottom and that should work.. Plus if you have a hammer then it might only cost you about 10-20 dollars for a heavy duty stake... I hope the end state helps you at all... God bless,
joe
Keojoe1981 is offline
post #27 of 29 Old 08-13-2011, 07:53 PM
Lre78hd
What a bout a couple mobile home tie downs? Screw them in the ground and unscrew when done. Not bulky relatively easy to store. Just a thought
Lre78hd is offline
post #28 of 29 Old 08-13-2011, 08:58 PM
TJDaveX
Motorized toy collector
TJDaveX's Avatar
I'm picturing metal stakes in the ground with all that tension on the line. If they were to suddenly let go, someone could get an eye put out.
But I guess if you are alone, coming home with one eye is better than not coming home at all.
I prefer the second, third, or more Jeep option.
TJDaveX is offline
post #29 of 29 Old 08-14-2011, 11:59 AM
hrt4me
Originally Posted by MayRoll View Post
Pull Pals are pricey, but they work well in dirt, sand and packed snow.
thanks for the link, I am going to order one
hrt4me is offline
R/C winch plate & 8500lb Super winch on factory bumper. fernjack JK Wrangler Technical Forum 17 11-23-2010 10:12 AM
Dangerous Off Road flip... thank God for those trees.. Phrankoff Wrangler General Discussion 11 05-27-2010 10:11 AM
20' Bamboo Trees in My TJ myuserid Wrangler General Discussion 1 03-20-2010 09:20 AM
Pics of new MOPAR winch bumper, the one w/fog light cutouts & Hyd winch nycrd JK Wrangler Technical Forum 25 12-11-2009 05:33 AM
Pics from Trees ranch this weekend wes19d Wrangler General Discussion 3 03-29-2009 11:17 PM
