How to tell if control arm bushings are bad? - JeepForum.com
post #1 of 2 Old 07-31-2015, 09:41 AM Thread Starter
matholland
I have a home made long arm lift out of DOM tubing on my WJ. The upper rear links have heims threaded into the DOM tubing. I have had a noise since I bought the jeep and have been trying to track it all down. I have replaced the heim joints on the back. All of the other joints are the johnny joints. It is 3 linked up front and 4 linked in the rear.
When I drive and hit bumps, it sounds like the damn axles are about to fall out
The back uppers are tight, they were very loose before. From what I can tell the rest of the long arms are tight. In the past I have been able to rotate the tire and see where the play is coming from. It has to be the control arm bushings...but rather than pulling them all off 1 by 1 and inspecting the johnny joints, whats another way of checking it?
matholland is offline
post #2 of 2 Old 08-02-2015, 02:04 PM
GilaMtnJeep
GilaMtnJeep's Avatar
Forgive me, but I must ask.
How are your shock bushings? They can make a bunch of racket when worn.....
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
