how to tell how much a yj has been lifted - JeepForum.com
post #1 of 5 Old 05-17-2011, 03:56 PM Thread Starter
beardown
Is there an easy way to figure this out? Thanks
beardown is offline
post #2 of 5 Old 05-17-2011, 04:09 PM
KLT88YJ
If you can run larger than stock size tires with little to no wheel well/ flair rub!! (31"+ sizes). Generally 2.5" will afford clearance for 31". 3-3.5" 32"~33". 4-4.5" 33~35". All are dependant on spring quality. The YJ has small wheel well openings. You can always throw on a set of TJ flairs, cut the existing metal out and Viola!! Now your running 33" with (est. 2.5" of lift!!
KLT88YJ is offline
post #3 of 5 Old 05-17-2011, 07:12 PM
WakeDoctor
The rear diff is 9" from the ground. This is only changed by larger tires.
The rockers are 18" from the ground. This is changes by body/suspension lifts and larger tires.
Measure from the ground to the rocker. The measurement will = X
Measure your rear differential clearance. The measurement will = Y
X" - 18" - (Y" - 9") = The total inches of body / suspension lift you have.
Example: A jeep that measures 11" at the diff (Y) and 23" at the rockers (X) would have around 3" of lift.
WakeDoctor is offline
post #4 of 5 Old 05-18-2011, 07:37 AM Thread Starter
beardown
Hmmmmm, well I have 32s on it rt now, no rub.....the reason I ask is that I'm looking at new shocks and I know they are lift specific... the person that I bought the yj from told me it was lifted 3 inches but I've always been skeptical of that..
beardown is offline
post #5 of 5 Old 05-21-2011, 05:55 AM
WakeDoctor
Always be skeptical of a man who is getting rid of a jeep.
Lifted or not? williamsmithaud Tires & Wheels 1 09-08-2008 07:16 PM
want see lifted cj6 79cj6 Tires & Wheels 0 07-24-2007 01:41 AM
is my jeep lifted jaysky Tires & Wheels 6 11-11-2006 08:40 AM
I'm lifted!!! djaychris Tires & Wheels 12 06-02-2006 04:19 PM
Already lifted? or NOT Jeep Daddy Tires & Wheels 3 01-30-2002 05:15 PM
