-   General Jeep & Off-Road Equipment (http://www.jeepforum.com/forum/f27/)
-   -   how to tell how much a yj has been lifted (http://www.jeepforum.com/forum/f27/how-tell-how-much-yj-has-been-lifted-1215610/)
beardown 05-17-2011 03:56 PM
Is there an easy way to figure this out? Thanks
KLT88YJ 05-17-2011 04:09 PM
If you can run larger than stock size tires with little to no wheel well/ flair rub!! (31"+ sizes). Generally 2.5" will afford clearance for 31". 3-3.5" 32"~33". 4-4.5" 33~35". All are dependant on spring quality. The YJ has small wheel well openings. You can always throw on a set of TJ flairs, cut the existing metal out and Viola!! Now your running 33" with (est. 2.5" of lift!!
WakeDoctor 05-17-2011 07:12 PM
The rear diff is 9" from the ground. This is only changed by larger tires.
The rockers are 18" from the ground. This is changes by body/suspension lifts and larger tires.
Measure from the ground to the rocker. The measurement will = X
Measure your rear differential clearance. The measurement will = Y
X" - 18" - (Y" - 9") = The total inches of body / suspension lift you have.
Example: A jeep that measures 11" at the diff (Y) and 23" at the rockers (X) would have around 3" of lift.
beardown 05-18-2011 07:37 AM
Hmmmmm, well I have 32s on it rt now, no rub.....the reason I ask is that I'm looking at new shocks and I know they are lift specific... the person that I bought the yj from told me it was lifted 3 inches but I've always been skeptical of that..
WakeDoctor 05-21-2011 05:55 AM
Always be skeptical of a man who is getting rid of a jeep.
The time now is 11:38 PM.
