how strong is jb weld? - JeepForum.com
post #1 of 11 Old 01-01-2010, 08:15 PM Thread Starter
fabian9931
How strong is jb weld? I dont have a welder and I dont know anyone who has a welder also. So I wanted to make my own roof rack out of conduit. I have a miter saw that I would just to 45 the corners. My question is how strong is jb weld. It would be used on the 45 angle corners and down the middle to act as a T. I used it to jb weld a BOV on my turbo integra and held great, but thats PSI. I will just use it to carry my spare tire and also maybe some lugage. I dont go off roading
It will be bolted to my stock rails
fabian9931 is offline
post #2 of 11 Old 01-01-2010, 08:35 PM
DINOCAVE
formerly CPT Jeep
DINOCAVE's Avatar
In my experience, JB Weld is about as strong as Elmer's glue.
DINOCAVE is offline
post #3 of 11 Old 01-01-2010, 08:40 PM
NoVaHunter
This.
10char
Originally Posted by KHoff90 View Post
Has anyone really been far even as decided to use even go want to do look more like?
NoVaHunter is offline
post #4 of 11 Old 01-01-2010, 08:57 PM
-AC-
1977 CJ5
Used within a VERY specific range of use, it can be incredibly strong, but not for what you're considering. Not to be a wet blanket, but I don't thing conduit will work that well as a rack, either. I would think that the weight of a spare tire would eventually bend it, what with all of the bouncing and etc. that your vehicle goes through. Gas pipe would work better, but then you're back to welding. But, you can buy a 110volt small mig welder pretty cheap these days. I think you could get a non-name-brand for $100 or less. Then, get some scrap pipe and practice for a couple of days. You'll get it figured out, and then you have a new tool and a new skill!
Oh, and JB Weld DOES NOT hold up to race gas. There's a (funny) reason I know this...
"Damn Everything But The Circus..." e.e.c.
-AC- is offline
post #5 of 11 Old 01-01-2010, 09:08 PM
Treeslam
Duck tape would probably be just as strong as the JB. If you talking about using thinwall EMT conduit (typical conduit we run wire through) it will not support much weight at all. You could probably use rigid EMT minimum 1" and it would be much stronger. Also, the rigid will hold up to a welder. Just my $.02.
94 YJ White (Sold 4/19/12)
07 JK Black (Sold 7/20/10)
09 Maxima(hers)
09 GMC(work truck)
Treeslam is offline
post #6 of 11 Old 01-01-2010, 09:14 PM
Rebel442
Might wanna think about the liability problems if your roof rack comes apart and dumps a tire on the highway. A good rack is only like $300 it might be worth saving for.
It Wouldn't Be A Project If Everything Worked Right.
Rebel442 is offline
post #7 of 11 Old 01-01-2010, 09:22 PM
-AC-
1977 CJ5
I still think you should learn to run a small MIG. A skill you will find uses for the rest of your life, and it's actually quite fun.
But, having said that, I suppose you COULD go to Lowe's or Home Depot and buy galvanized or black pipe, and also the pre-made joints. Between some good pipe-dope and a pair of stout wrenches, you might be able to get it solid enough.
But, you really should weld it...
-AC- is offline
post #8 of 11 Old 01-01-2010, 09:27 PM
Sloth_Fratelli
i wouldnt use JB if your putting all that on there you dont you use a corner bracket and metal screws or bolts at the 45 angles? damnit now i wanna come over and help you get this sum***** done. only two reasons i wont is im a few hundred miles away and ive watched jersey shore before, never gonna go east of pennsylvania if i dont have to
Originally Posted by incagoldjeep View Post
it was taking you down with it. it was like a jeep zombie.
Sloth_Fratelli is offline
post #9 of 11 Old 01-01-2010, 09:41 PM Thread Starter
fabian9931
thanks for the replies guys. fist pump!
post #10 of 11 Old 01-01-2010, 10:13 PM
NoVaHunter
That wouldnt happen to be a reference of Jersey Shore would it?
post #11 of 11 Old 01-01-2010, 11:01 PM
Sloth_Fratelli
Originally Posted by Sloth_Fratelli View Post
ionly two reasons i wont is im a few hundred miles away and ive watched jersey shore before, never gonna go east of pennsylvania if i dont have to
brah.
ten word minimum takes away the sting of that
how strong is a NP 208 TC green_jeep Engines & Drivetrain 0 01-25-2010 11:55 AM
ARB Compressor Strong enough? Chipper004 General Jeep & Off-Road Equipment 10 11-06-2007 06:24 AM
How Strong? djXternal General Jeep & Off-Road Equipment 3 10-20-2006 04:56 PM
Stick weld or MIG weld? theboxman71 Fabrication Shop 39 10-05-2006 06:46 PM
How strong is the super 35 kit? Masterchief Engines & Drivetrain 14 03-10-2006 06:51 PM
