How to Paint White Letters on Tires - JeepForum.com
post #1 of 13 Old 05-27-2008, 11:05 AM Thread Starter
BrooklynBridger
I have 4 fairly new Cooper 225/75/R15s. Nice tire, but they'd look much better on my YJ if the Cooper lettering on the tire walls were white! Does anyone know a good way of painting them white? I was thinking of just the raised outline of the letters not filling the inside of the lettering. What type of white paint would I use to stick to the rubber?
Thanks!
Mark
BrooklynBridger is offline
post #2 of 13 Old 05-27-2008, 05:27 PM
CLNinja
CLNinja's Avatar
are the letters white on the other side of the tire?
if so then you just have to have them flipped around at a tire shop... they were probably mounted with the black letters out
Matt
**September 2009 Grand Cherokee Of The Month**
CLNinja is offline
post #3 of 13 Old 05-28-2008, 07:32 PM
robola
Tire marker
You can use wite permenent marker pen.
robola is offline
post #4 of 13 Old 05-29-2008, 05:43 AM
lobukjeep
shoe polish
"We don't call you son 'cause your bright"
lobukjeep is offline
post #5 of 13 Old 05-29-2008, 10:08 AM Thread Starter
BrooklynBridger
Thanks. Only white stripe on the other side, no white letters.
I think shoe polish will wear off after each wash. Perhaps the permanent paint marker may do a little better. I guess I'm wondering if there is a type of white paint that bonds to the rubber so it can be brushed when cleaning the tires and won't come off (reasonably).
Mark
post #6 of 13 Old 05-29-2008, 10:13 AM
xxxflhrci
xxxflhrci's Avatar
A whitewall on the other side? What are they all season radials? At any rate, you can get a tire pen:
http://www.autobarn.net/trimpen.html
xxxflhrci is offline
post #7 of 13 Old 05-29-2008, 10:23 AM
tjsahara1979
I think he means they're not solid white. Like this:
As opposed to this:
tjsahara1979 is offline
post #8 of 13 Old 05-29-2008, 10:26 AM
xxxflhrci
xxxflhrci's Avatar
As opposed to this:
I'm not so certain. He says he wants to just paint the outline of his letters, not fill in the middle, so they aren't like your first example.
post #9 of 13 Old 05-29-2008, 10:27 AM
Mudweiserjeep
Mudweiserjeep's Avatar
1970 CJ5
Testors model Paint. Model paint but does a good job. If outlining letters...Testors make a paint pen......easy to use.
Tim - KC8UXU
1987 XJ (Evil) (Parting out)
1970 CJ5
231 V6
2.5"bds lift, 0.75" shackle lift, 4:88 gears
31" Old tires..... need newer ones....going 35"
Mudweiserjeep is offline
post #10 of 13 Old 05-29-2008, 10:57 AM Thread Starter
BrooklynBridger
ACtually, I am undecided about painting just the outline or filling them in. I can start at least with the outline and go from there.
They are all-season radials I believe. They came with the Jeep with only 1000 miles on them. I just really like the white letters and don't want to buy new tires just for that. Plus the tires are a decent size for my daily driver (225/75/R15. Althought I with the tread was wider, not 75 including the side bulge)
Thanks. I'll look at the pen idea...
mark
post #11 of 13 Old 05-29-2008, 08:55 PM
jormar1990
jormar1990 is offline
post #12 of 13 Old 05-30-2008, 07:59 PM
goatboy
If you've ever Armor All'd them, or used anything with silicone on them, forget it...it won't take. Secondly, if you are going to use your Jeep for what it's intended for, anything on those letters is gonna come off mo' ricky tick. The white letters on tire goes pretty much all the way thru the top ply...or the second to top ply, whatever.
goatboy is offline
post #13 of 13 Old 05-31-2008, 01:27 PM Thread Starter
BrooklynBridger
Well, after all that, I found 4 used (less than 5k) BFGoodrich All-Terrain T/A KO 30/9.5/R15 including American Racing Outlaw II rims (need refinishing) for a good deal. When I saw that I said, "Forget white lettering the Coopers!"
Now For Sale: 4 Cooper 225/75/R15 NO White letters.... Also, 5 OEM Jeep Wrangler Alloy Rims (5 spoke), completely refinished to perfection. (I'll be posting these in the for sale box...)
Thanks all for the help. I was going to try the white paint pen, btw.
Mark
Paint White Letters? Silverton34 Tires & Wheels 5 01-12-2010 04:55 PM
White Letters In or Out? bruker Tires & Wheels 27 11-21-2006 02:29 PM
Tires-white letters in or out? RaoulR1 Tires & Wheels 68 08-28-2006 12:30 AM
White letters in or out? onlyone Tires & Wheels 16 01-18-2005 09:00 PM
White letters? OwnAccord Tires & Wheels 19 07-18-2002 05:33 PM
