How much of a lift do you think I have? - JeepForum.com
post #1 of 6 Old 04-04-2009, 06:39 PM Thread Starter
mmerlina
Image Glassworks, Inc.
mmerlina's Avatar
Hey folks, the PO put a skyjacker lift in, but I have no idea what size. I guessed a 3".. but it never really mattered up until this point. But I'm trying to buy sway bar quick disconnects, and most of them come 0-2.5", and 2.5-4".. so now it matters. ;]
Mike
1986 Jeep CJ7 (
Remanufactured 258, ARB lockers front & rear, 4.10 Yukon gears, 35x12.5" Super Swamper SSR's, Motorcraft 2100, 4.5" Rubicon Express Extreme-Duty lift, York 210 OBA, Big Daddy steering, Tatton rear CV driveshaft, Herculined interior, TJ flares, lots of body & upholstery work
mmerlina is offline
post #2 of 6 Old 04-04-2009, 07:11 PM
flexsaharatj
looks like your running 31's... so I'd say 2 inch BB
flexsaharatj is offline
post #3 of 6 Old 04-04-2009, 07:18 PM Thread Starter
mmerlina
mmerlina's Avatar
Those are 33's.. would it help if I measured the distance between the fender and the tire?
Mike
1986 Jeep CJ7 (
mmerlina is offline
post #4 of 6 Old 04-04-2009, 07:25 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
CJs require more lift to run the same size tire a TJ does, I'd say it has at least a 3" lift to give that much clearance over 33" tires.
Gone on vacation until August 25.
Jerry Bransford is offline
post #5 of 6 Old 04-04-2009, 07:28 PM Thread Starter
mmerlina
mmerlina's Avatar
Well that's what I've been guessing too, and the guy at my shop thinks the same thing. Wish I knew for sure, but I'm going to buy the kit for the 2.5-4", if it doesn't fit, worst case scenario is I have to swap it. Thanks a lot for all the input.
Mike
1986 Jeep CJ7 (
mmerlina is offline
post #6 of 6 Old 04-05-2009, 05:43 PM
shrewd
Find out the stock rocker height and work backwards accounting for difference in tire size vs. stock. I've done that in the past.
I used this method and it told me that my stock springs were sagging 2" below factory level.
Looks like ~4" to me.
My D35 grenaded at 65mph, fun times.
shrewd is offline
Pro Comp Lift VS Rough Country lift Footlead Tires & Wheels 4 07-22-2010 12:20 PM
Can I clear 32x11.5x15s with only a 2.5 suspension lift (no body lift) on my 2006 TJ? ddonjon General Jeep & Off-Road Equipment 3 04-21-2009 10:49 AM
Whats the diff between Body Lift and Suspension Lift? loudog3114 Tires & Wheels 7 02-01-2005 02:27 PM
Will a Lift Void my warrany - Lift Suggestions needed johnobennett Tires & Wheels 10 10-23-2003 12:04 AM
Spacer Lift or Body Lift?? Help Guys!! TJ LUVER Tires & Wheels 2 03-04-2002 09:45 PM
