How to keep interior light off when you take doors off?
| Front and rear Drive shafts @ free shipping | Poison Spyder February Special: FREE Rubber Liners when yo | Slappin' on 61,510 Rigid Industries Lumens for Big Red |
#1 | |
how would i keep the light off when I take my doors off?
#2 |
There is a attachment you can buy that takes care of that. jcwhitney?
#3 |
Pull fuse #4
This will also disable your "lights-are-on,but-ignition-is-off" alarm. The clip mfinn is talking about looks like this: ![]() http://www.quadratec.com/products/13029_100.htm Last edited by CNY; 04-13-2008 at 07:36 PM.. |
#4 |
#5 |
sweet just orderd one thaks guys
#6 |
it was stupid when I did it and I'm kinda regretting it now, but I just glued the plunger in.
now the only way my dome light comes on is when I turn the knob, doh!!
À tout le monde, À tout mes amis, Je vous aime, Je dois partir. These are the last words I'll ever speak and they'll set me free. Officially driving the Jason Ellis Bandwagon |
#7 |
Lights off/doors off
If you want a quick fix just reach behind the door switchs and diconnect the wires
#8 |
Semper Fi
Carefully pry pin out.
![]() Place in vice, vice will keep switch closed and drill "pin" sized hole through pin and sheath. ![]() Ready to install ![]() All done. ![]() Time= 20 minutes Cost= about .05 for safety pins
Skyryder Proud user of the "K.I.S.S." Principle.'97 Black TJ - 4 banger - 5 speed Black Jeep Society #264 |
#9 |
That's the best "Cheap" I've seen in a Long time!!!!
04 L J Travel'n Gadget Show KE5PPH |
#10 | ||
Pull fuse #4 behind your glove box.
Spyderbyte
#11 |
I couldnt find the fuse and got frusterated... so I pulled my bulbs... now i feel like a moron
#12 |
Trust me....
Just take your foot out of your sandal and hold the plunger in with your big toe.
Of course, you will need someone riding shotgun. ![]()
Patriot Blue 2001 TJ Everything I need to fix on the heep: ABS indicator, speed 4 on the blower fan, torn softop over driver's head, both seat release/tilt cables, missing center cap on spare, broken under hood light, wire up the CB, wiring problem with the reverse lights, broken bottle jack, leaky front and rear pinion seals, loose trackbar relocation bracket, torn drivers seat on the side, broken center console lock, lost nuts for door hinges, squeaking centering ball, loose parking brake cable, oil change and rotate the tires. My build threadhttp://www.jeepforum.com/forum/f22/free-wife-good-home-pics-included-528892/ |
#13 |
Skyryder, Nice fix!
Semper Fi Marine. |
#14 |
Awesome
GReat post on the light switches only correction I would make. A. you don't need to use a safety pin just cut a paper clip (a thicker one) in half. Also for drilling you don't have to pry the switch out and vice it, just use a very small bit and hold the switch closed with your other hand while you carefully drill through it with the other ( don't slip and hit your hand you got the warning). Did it in less than 4 minutes works great and I can still use the switch.
#15 | |
Pins suck!
Cost: $0.00 Time: 45 seconds (or so?) P.S. - Just remember to turn off your lights since the reminder buzz will be gone! P.P.S. - Nice fix Skyryder! |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
