#1 | |
I heart bacon and pie
how to empty a jerry can
Is there some trick to getting gas out of a gerry can? Mine has no vent hole in it and it takes forever to pour gas out of it. Do people typically drill and tap these to put in some kind of vent hole? I just wondered how others use gerry cans.
#2 | |
ROCK WHEELER
http://www.outboardmotorparts.com.au/Default.asp?p=PT&id=32 USE FOR PICTURE ONLY http://www.peakbusiness.co.uk/canalpages/liveaboard5.html
___________________________________________ In or Near San Diego, CA? Click Here Black Jeep Club Member #1016 Senior Member: Jeep Repair Club, San Diego Chapter
#3 |
For god's sake empty it before drilling the hole.
I think Wedco gas cans have a vent-pipe inside them that comes up to the filler neck. https://www.expeditionexchange.com/wedco/ |
#4 |
Actually, if you're gonna drill the thing, it would be safer to drill it with the can as FULL of fuel as you can get it.
Better yet, fill it with water, drill, empty it, add fitting, let can dry thoroughly before adding fuel again. If you're worried about it you can add some dry gas, upon fuel refill, but if you let it dry sufficiently, the dry gas is unnecessary. It's the fuel/air mix that explodes, you don't want any air in the thing when you drill. Of course, if it's a new unused can, drill away.
But what do I know? I'm old. |
#5 |
How to empty a Jerry can:
Drive a Jeep. |
#6 |
Join a 4x4 Club
I have a spare old electric fuel pump. I added a couple clear hoses to it and a power cord. Poof, mega pump.
'93 YJ, '02 GM 4.3 Vortec V6, SOA, dual ARB's, 8.8+D30(w/WarnHubs), 4.88 gears, 35" Trxus M/T's, AX15, 15x7 wheels, NP231+4:1+SYE+2LO, York OBA, Warn M8000, no top or doors Apr-Oct. Member and Web guy: New Mexico 4 Wheelers |
#7 |
Go buy some some cheap brake bleeders, or a curtiss valve and tap it into the can ..when you want to pour the gas, open the valve... keep fuel from leaking out with just a hole in it
#8 |
hold the can flat, (parallel to the ground), and it will pour just fine.
#9 |
fill full of water first i know a guy who cut on a gas container empty well he has no legs now.
#10 |
x2 works great!!
You're in charge of two things around here, Jack and Sh-t and Jack just left town |
#11 |
What size filler tube are you using? 1/2 inch or 1 1/4 inch? that wil make a big difference on how fast the fuel flows from the can into the tank.
#12 |
It's not that, it's the air that has to replace the fuel. There is usually no air hole.
Member 134 of the White Jeep Club 31" BFG A/T's, 130w KC Hilites |
#13 |
#14 |
I just stick a hose in the can and siphon the gas into the tank, raising one end of the can 3/4 inch helps if you put the hose to the bottom on the low side. The flex nozzles all leak as you dump the gas into the tank (they leak worse if you vent the can).
Enjoy!
...a well prepped, well driven, vehicle should do well in any terrain, including the highway. Carburetors became obsolete during the last century... do what ever it takes to get fuel injection...It makes bigger grins off road. |
#15 |
Just to let you know, the old style Jerry Gas Cans (military style) are not DOT approved and are actually illegal to use now. Plus they are in the process of passing a law that gas cans will require a child safe lid too. There is a lid for the old style that has a spill proof filling tube and will make them legal, but will not be legal when the new law goes into effect (child safe lid).
The old style are just slow to empty and usually leak all over the place. puttputt56 |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
