How do I removed a bolt with a stripped torx head? - JeepForum.com
post #1 of 12 Old 07-15-2008, 08:46 PM Thread Starter
Fargo
I was going to remove my rear gate hinges so I could paint them. But on the second bolt, I stripped out the Torx head. Any ideas how to remove it? Or am I best off to just leave the hinge attached to the Jeep and tape everything up and paint them in place?
I've heard a lot of cursing of torx bolts on the forum in the past so I figure someone must have figured out a way to remove them once the head is stripped. Let me know how. Thanks
6spd manual
LJ Owners Group member #110
Fargo is offline
post #2 of 12 Old 07-15-2008, 09:44 PM
Matt Graham
Matt Graham's Avatar
I drilled the head off. But be careful!
Instagram:
Twitter:
Youtube:
My Build Thread:
F-250 7.3 Tow Rig Build Thread:
Matt Graham is offline
post #3 of 12 Old 07-15-2008, 09:46 PM
Ultimatecarman4
If you were really lucky you could use a stripped bolt remover.
Ultimatecarman4 is offline
post #4 of 12 Old 07-15-2008, 09:52 PM
PBR
PBR's Avatar
I drilled them and welded a bolt to them.
PBR is offline
post #5 of 12 Old 07-16-2008, 04:39 AM
1995sport
1995 XJ Cherokee
I would get a stripped bolt remover if you can get one large enough. or try an easyout. if all else fails weld a bolt to it.
1995sport is offline
post #6 of 12 Old 07-16-2008, 08:54 AM
rubiweeler
I welded a nut to mine, if you weld it inside the nut it protects the paint a little more. I have never been able to get a stripped torx out with an easyout, they all break off and I end up welding anyway.
Superior axles doesn't honor their warranty. Don't buy from them.
rubiweeler is offline
post #7 of 12 Old 07-16-2008, 09:18 AM
YJdad
^^ Agreed - Don't bother with the Easy Outs - I drilled the ones that didn't come out and replaced them all with hex head bolts.
94' YJ Stock 2.5L -
/ BFG 30x9.5x15 / Herculiner / Stereo console - Currently parked for overhaul
98' ZJ GCL - Stock V8
75% of the world is covered by water, the rest is covered by Jeep!
YJdad is offline
post #8 of 12 Old 07-16-2008, 09:44 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
As recommended above, just use a drill bit that is just slightly larger in diameter than the threaded part of the bolt is. When the bolt head comes off, you can remove the hinge which will leave enough of the stud protruding to remove it with vise grips. But if you have access to a welder or have a friend who welds, I'd probably weld a big bolt to it instead which makes removing it pretty easy.
Gone on vacation until August 25.
Jerry Bransford is offline
post #9 of 12 Old 07-16-2008, 10:24 AM Thread Starter
Fargo
Thanks to all for their help.
Thank you Jerry for providing a little more detail on exactly what everyone else was explaining. I think I will try removing the other bolts. If just the one get stripped out I will drill it out and remove with a vise grips, but if the other strip out as well I will just paint the hinges in place. Thanks again.
6spd manual
Fargo is offline
post #10 of 12 Old 07-16-2008, 10:34 AM
Jerry Bransford
Administrator
You can minimize the chances of stripping out more bolt heads if you're careful. Use a good sharp new torx head adapter, hold it firmly and squarely into the bolt head, and have a lot of leverage available which will allow better control which will minimize the chance of the torx slipping out of the bolt and stripping it. I always use a long breaker bar (like 18" to 24" long) instead of my half-inch ratchet wrench for this particular job which gives me the increased leverage and thus the increased control that is needed.
post #11 of 12 Old 07-16-2008, 11:04 AM Thread Starter
Fargo
Thanks Jerry. I think a twisted torx head is what messed up this bolt in the first place. I pushed pretty hard on the first one and once it was loose, I noticed my torx head was twisted. I don't know if it was before or not. I don't think so. I probably shouldn't have tried it on the 2nd one but I didn't think they would strip out that easy. I've never had trouble with torx before. But tonight before I try any more, I will run out to sears and see if they will replace my twisted head. I'm not sure how much the Craftsman warranty covers. Thanks again.
6spd manual
Fargo is offline
post #12 of 12 Old 07-16-2008, 11:17 AM
Jerry Bransford
Administrator
That twisted torx adapter should warrant a no questions asked replacement. Sears is pretty good about lifetime replacements on their non-electric Craftsman tool line.
Stripped Femal Hex Bolt.. Help Please.. jeeps4life General Jeep & Off-Road Equipment 6 11-09-2009 07:19 PM
Stripped Female Hex Bolt.. Help Please.. jeeps4life Fabrication Shop 10 11-04-2009 07:44 PM
specific torx bit for stripped tailgate hinge bolts? first5.0 General Jeep & Off-Road Equipment 10 05-15-2008 07:51 AM
Ahhh!!! Stripped Rod Bolt! gumcrew2 Engines & Drivetrain 2 10-28-2005 07:17 PM
Help please...stripped out a hole on head Baloo Engines & Drivetrain 4 04-12-2004 12:02 AM
