How do i get a 46 willys on a trailer? - JeepForum.com
post #1 of 9 Old 01-25-2014, 08:15 PM Thread Starter
Amcxjkid
So Today I payed for 2 1946 Willys CJ 2's. Well 2 of my buddy's and my dad and I took my buddy's trailer with us to go get them. Trailer is 24' and has ramps on the back but there pretty a steep. So we backed the truck to the 2 jeeps and broke them loose from the ground sense they have been sitting and also it's 5 degrees out. But ones we did get them broken loose some of the tires wouldn't turn ( could be because there destroyed or bearings are siezed etc.) so we tried using a come a long but it wasent long enough so we used some ratchet straps to lengthen it. But I jaut don't feel safe using the come along to try and pull the front of the jeep onto the trailer. Anyone have any suggestions? ( I bought the 2 to the far left, both of them for $450)
Amcxjkid is offline
post #2 of 9 Old 01-26-2014, 12:10 AM
firejeep42
Jackknife the trailer and use another truck to pull them up onto it if you don't have a winch
~Dave~
firejeep42 is offline
post #3 of 9 Old 01-26-2014, 01:03 AM Thread Starter
Amcxjkid
Originally Posted by firejeep42
Jackknife the trailer and use another truck to pull them up onto it if you don't have a winch Sent from my iPhone using JeepForum
well only other vehicle we have is my xj unless my buddy comes with his silverado but I know he can't come in he morning.
Amcxjkid is offline
post #4 of 9 Old 01-26-2014, 02:56 AM
scottmphoto
1991 XJ Cherokee
Until I put a winch on my trailer, I used a 2-ton come-a-long and chain.
scottmphoto is offline
post #5 of 9 Old 01-26-2014, 08:58 AM
scramblered
Years ago I had to move my uncle's mobile home and unfortunately trees had grown up on each end so that hooking a truck to it was not an option. A friend of mine who works for a building moving company suggested that I jack up the the mobile home and slide plywood under the tires . We then took buckets of water and poured it on the plywood until we had a nice layer of ice. All we had to then was pull it sideways til we cleared the trees and was able to hook a truck up to it. I was surprised how easy it slid on the ice. Don't know if that helps in your situation but it may be worth a try. Good luck, Dave
"Not all who wander are lost."
scramblered is offline
post #6 of 9 Old 01-26-2014, 11:10 AM
strvger01
1966 CJ5
might be easiest/cheapest to just get a manual winch put on the trailer. i'm thinking of the manual, load winches on semi trailers. get 20' of 10k# strap and chain to make up the rest of the distance and you should be good to go. something like this: http://www.northerntool.com/shop/too..._397728_397728
not the best option, but cheap and fast to bolt on your trailer.
1966 CJ5A, mods are coming
1966 Wagoneer, bone stock
strvger01 is offline
post #7 of 9 Old 01-27-2014, 03:33 PM
TSEJEEPERS
Just use another truck or Jeep to pull it onto the trailer.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #8 of 9 Old 01-27-2014, 03:40 PM Thread Starter
Amcxjkid
I ended up getting a 2 ton come along and used a chain and that worked good. Second jeep the land owner used his front loader!
Amcxjkid is offline
post #9 of 9 Old 01-28-2014, 12:18 AM
WSS
WSS's Avatar
1972 CJ5
The ice/slick plywood sounds like a winner to getter done.
WSS
If you are a Purist, don't click here:
My CJ5 Build and fun stuff:
WSS is online now
