How to build a Cherokee rock crawler ? - JeepForum.com
post #1 of 7 Old 05-18-2011, 09:21 PM Thread Starter
ParisDakar
KJ Liberty
So my Dad has an old Cherokee that he may trade. I'm thinking of buying it cheap & building a rock crawler so that my son & I can go crawling around the backwoods where I have some forest land.
I know very little about rock crawling other than to keep the undercarriage off the big rocks. I mostly drive sports cars on tracks so I'm used to driving fast so this slower stuff is new to me
So what are the most important things you need in a rock crawler. Obviously I'll need a large lift w enormous wheel travel, big tires, a winch, some underbody armor.
But how much hp & torque do I want ? Is the stock auto trans strong enough ? Can I swap the gears ? What else do I need ?
Thanks
ParisDakar is offline
post #2 of 7 Old 05-19-2011, 02:41 PM
nicexj
nicexj's Avatar
There is a ton of stuff you can do. If you wanted to to it right, I would recommend you go long arm, and not to tall.
This is a cool Y link kit. It comes with belly armor, and the arms. Match that with a Rusty's 4 or 6 inch lift.
TNT customs Y-link kit
Rustys 4.5" lift
I like to go low, and slow. Big lifts make you tipsy. Low and slow gets to go.
For some real eye candy check this out
Pirate4x4 Cherokee section
A solid jack, and a good set of wrenches are all just part of the investment in owning a Jeep.
2001 XJ 3" Rusty's aal, 31x10.5 Good Year Authorities Powertrax No slip Locker in the rear
nicexj is offline
post #3 of 7 Old 05-19-2011, 02:42 PM
nicexj
nicexj's Avatar
Also, a great read if you want some bathroom eye candy is Eric's book
High-Performance Jeep Cherokee XJ Builder's Guide 1984-2001
nicexj is offline
post #4 of 7 Old 05-19-2011, 03:46 PM
UnlimitedMatt
Check out NAXJA (North American XJ Association).
http://www.naxja.org
UM
UnlimitedMatt is offline
post #5 of 7 Old 05-20-2011, 10:08 AM
nicexj
nicexj's Avatar
First of all, not that JeepForum isn't great, and North American XJ association is also. But the Pirates are playing on a whole different level. I don't even talk there, I just look at all the awesome work that is going down.
One of my favorites. Removable top XJ
nicexj is offline
post #6 of 7 Old 05-20-2011, 10:13 AM
jreycnc
1980 CJ5
For rock crawling, you really want high clearance, not high lift. Low center of Gravity with as much undercarriage clearance as you can manage. You can usually do this with a smallish lift and cutting up the fenders. This will let you run bigger tires to get your pumpkins and drivetrain away from the ground while staying low(ish). Also, a good first step is to lock the front and rear axles to get better traction.
jreycnc is offline
post #7 of 7 Old 05-20-2011, 10:50 AM
nicexj
nicexj's Avatar
That is actually the logic behind the Ylink under belly armor that I was linking to earlier. It pulls your upper control arm mounts higher up than stock, and gives a smoother, higher clearance in the center of the under body. 4.5 inch lift is just taller than what I run, and I think I would be happier on 33s, so 3 inches just won't cut it without some serious body mods.
nicexj is offline
17 in rock crawler saintk99 Tires & Wheels 0 04-22-2011 09:17 AM
Rancho rock crawler Jakemd98 Tires & Wheels 1 09-28-2009 09:54 AM
Rock Crawler series 152??? KKiowaTJ Tires & Wheels 3 01-13-2009 07:59 PM
Rock Crawler Wheels Rick_W Tires & Wheels 1 10-22-2006 10:05 AM
Rock Crawler Rims Savage4x4 Tires & Wheels 6 09-22-2003 01:28 PM
