"hose" out interiors - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > General Jeep & Off-Road Equipment > "hose" out interiors
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! Hey Guys - Extreme Terrain Jeep Outfitters - ExtremeTerraiThe Original 3/8" Ruffstuff Diff Cover!
Unread 11-27-2014, 10:05 PM   #1
limey940
Hey
Looking at a jeep to get to and from beach. have dogs and we do beach stuff like paddleboarding. Is there a way to have an interior that I could just hose out?
Also if top is off and it rains are there potential electronic issues?
thanks
limey940 is offline   Reply With Quote Quick reply to this message
Unread 11-27-2014, 10:24 PM   #2
laffoonlagoon
Jeeps are the best you will find in that way. But when you take your carpet out you will get a lot more heat soak through the tub into the cab. Not terrible but very noticeable. I currently have no carpet in mine and have no problem. With top off when it rains the steering wheel is probably the most vonerable lots of stuff in there that shouldn't get wet. There are drain plugs in the floor you can remove when you hose it out.
laffoonlagoon is offline   Reply With Quote Quick reply to this message
Unread 11-28-2014, 05:56 AM   #3
limey940
Thanks a lot. I actually started searching the forum after posting and found lots of threads on this topic.
thanks again
cheers
Unread 11-28-2014, 10:17 AM   #4
1320yj
A set of heavy floor liners cut out a lot of the heat and can be easily removed and cleaned when needed.
Also bed lining the inside of the tub helps quiet the inside and helps with heat. I have both and it made quite a difference.
1995 2.5 5Speed SOA 33x12.50 Mud Rovers
1320yj is offline   Reply With Quote Quick reply to this message
