Quantcast Home made deflators... - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > General Jeep & Off-Road Equipment > Home made deflators...
Old 04-23-2008, 08:10 AM   #1
smcurry83
I'm interested to see what people have come up with for deflators. I've seen some dual, some quad and other misc stuff. I'm working on a dual deflator/inflator right now, so lets see what you guys are using.....
smcurry83 is offline   Reply With Quote
Old 04-23-2008, 12:29 PM   #2
Indy
Never underestimate the power of stupid.
Indy is offline   Reply With Quote
Old 04-23-2008, 12:49 PM   #3
kingvm
kingvm's Avatar
2005 WK
I use the ones found all over ebay for <$10.
Could not figure out how how to buy parts to make some for less than that.
05 Grand Cherokee Limited, 5.7 hemi, quadradrive II, Nav, 3" lift, JK Rubi wheels/tires, 4xGuard skids
kingvm is offline   Reply With Quote
Old 04-23-2008, 06:04 PM   #4
mikemc411
Locking tire chucks
I keep two locking tire chucks in my console... clip them on and deflate two tires at a time... Go between the two tires monitoring air pressure,,, when they are good I go to the other two...
mikemc411 is offline   Reply With Quote
Old 04-23-2008, 06:10 PM   #5
flatlander757
Now in the 937
flatlander757's Avatar
Look at aftermarket manual boost controllers for turbo vehicles, they work the same way and are quite reliable. I have one on my 90 turbo Sundance set to 15psi.
They're adjustable from about 6 to around 23 or so where more modifications have to be made.
Here's a link explaining them:
http://www.gusmahon.org/html/boostcontrol.htm
Intake manifold would be the tire valve stem and the wastegate can would be nothing, the atmosphere. and the 0.020" hole wouldn't be needed.
Now trying to make them for a reasonable cost, I think you're better off just buying some pre-made.
The lumbering steel-laden pig - 2003 TJ - 40" LTBs - D60/D70HD - 5.86s - Detroit lockers - 110" wheelbase
Build thread here.
Originally Posted by 2006 Sport
Being able to make vroom vroom noises in Tonys Jeep was the highlight of my life.
Check out my Youtube channel
Pictures of it wheeling at Bill's 491
And more pics from that trip here!
flatlander757 is offline   Reply With Quote
Old 04-23-2008, 07:16 PM   #6
smcurry83
I'll have to get pics soon, but the one I made has two clamping ball chucks (one for each side) that are fed to a valve, gauge and coupler. So I can hook up both front or rear tires, and air down while I watch the gauge. Then when it's time to air up, I just plug the coupler into the coupler on my front/rear bumper. This makes it so both tires have the exact same pressure. Pretty convenient...
Old 04-23-2008, 07:30 PM   #7
fast64
Gets the pressure down way faster than sitting there and holding the pin pushed down.
- Jimmy My take on going doorless in a 97+ Georgia Trail Riders
'99 XJ
fast64 is offline   Reply With Quote
Old 04-23-2008, 07:31 PM   #8
Benny2Times
Originally Posted by Indy View Post
I laughed out loud
Benny2Times is offline   Reply With Quote
Old 04-23-2008, 09:25 PM   #9
Ruthless
2X.... removing the valve stem is probably the quickest way to air down short of sticking an icepick through your sidewalls. You just got to be careful and not let the valvestem shoot out of your fingers from the pressure, and bring spares.
Ruthless is offline   Reply With Quote
Old 04-23-2008, 10:03 PM   #10
USMCredneck
USMCredneck's Avatar
1979 CJ5
x3. Most good tire repair kits have the stem tool ans a few spare stems as well.
79 CJ5. 258, T-18A, D20. 33s
Military Jeepers
USMCredneck is offline   Reply With Quote
Old 04-26-2008, 09:49 PM   #11
CNY
Laugh all you want. About 75 cents for a set of four, and nothing is faster, except removing the valve stems.
CNY is offline   Reply With Quote
Old 04-27-2008, 12:05 AM   #12
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
I used to use the below 4-hose "octopus I made for both deflating and refilling all four tires at once. I thought it was cool but it never seemed to get the tire tires filled or deflated evenly, even if I gave it a little extra time for the tires to equalize. Plus it was very slow to deflate or inflate the tires because the air valves in the tire stems stayed in place, it just pushed the little valve pins in to let air in or out.
Then I discovered Currie's tire deflator like is reviewed at http://www.rockcrawler.com/techreports/curriedeflator/currie2.htm
The Currie deflator is easier and MUCH FASTER to use because it has a nifty mechanism for removing the center tire valve so it dumps the air out in seconds, plus it keeps the valve inside the deflator so it's easy to reinstall it without ever even touching it. It now only takes seconds to deflate my tires, I'll never use my "octopus rig" again.
Gone to King of the Hammers, back Sunday!
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Old 04-27-2008, 07:25 AM   #13
sportcoupe
Originally Posted by thedirt View Post
Nice! I have to pick up one of those: http://www.currieenterprises.com/CESTORE/Product569.aspx?id=1236
Out of curiosity, does it damage the wheel stem or anything like that over time? Taking it in and out can't be good for it, no?
They say it lets the air out really fast. How fast are we talking? Like 35psi - 10psi in like.. 10 seconds or 60 seconds?
I'd say 10 seconds is a reasonable estimate for the Currie EZ tire deflater. Pulling the core is very fast at air removal.
sportcoupe is offline   Reply With Quote
Old 04-27-2008, 03:51 PM   #14
Jerry Bransford
So long as you're not a gorilla that can't screw something in without cross-threading it, it's not going to affect the life of anything on or in the tire stem in a meaningful way.
So far as time goes, I'd say it takes my 35" tires from 28 to 7-8 psi in maybe 10-15 seconds at the most but I never actually clocked it.
Getting Savvy...
Old 04-28-2008, 06:32 PM   #15
TSEJEEPERS
Have one of these on each valve stem. Way quicker to just take the valve core out. This way you always have the remover with you.
http://www.farmandfleet.com/catalog/image.aspx?i=023090
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list. www.mijc.org
TSEJEEPERS is offline   Reply With Quote
Glock Forum
