Hi lift - JeepForum.com
post #1 of 17 Old 08-01-2011, 06:25 PM Thread Starter
1murderedjeep
Hi lift
Hey guys I am looking for a hi lift and don't want to spend much. My question is would anyone recommend this one? If not what would you buy for less than about 75 bucks? Thanks
http://www.farmandfleet.com/products...k#.Tjc81yd5mc0
1murderedjeep is offline
post #2 of 17 Old 08-01-2011, 06:27 PM
biffgnar
biffgnar's Avatar
My recommendation . . . forget a hi lift and spend your money on safer, more practical mods.
Dakar Style Rally Raid in North America: www.sonorarally.com
biffgnar is offline
post #3 of 17 Old 08-01-2011, 06:33 PM
hammerz71
I've got a Hi-Lift, had a couple of them over the years, they are invaluable tools, but I think the single worst thing you can use one for is to jack up a vehicle...
2002 Jeep Grand Cherokee Overland
Old Man Emu HD coils, 265/65/17 Nitto Terra Grapplers, Warn M8000, home made light bar, Cepek 130 watt lights, Hella 500s
CURRENTLY REBUILDING THE 4.7 HO ENGINE
hammerz71 is offline
post #4 of 17 Old 08-01-2011, 06:36 PM Thread Starter
1murderedjeep
Don't think the stock jack will lift my truck any more it's to tall. Plus a hi lift seems more stable when on the trail doing a repair or trying to get unstuck.
post #5 of 17 Old 08-01-2011, 06:44 PM
biffgnar
biffgnar's Avatar
On my phone so can't see your profile but stock bottle jack works up to 35s. Hi lift is anything but stable. Can be dangerously unstable in fact. Situations where it is only way to get unstuck rare IMO.
biffgnar is offline
post #6 of 17 Old 08-01-2011, 06:55 PM Thread Starter
1murderedjeep
Sweet then I'm good only have 33s I just thought the bigger base on the hi lift was better. But I'm new to this kind of stuff and that why I ask before buying. Thanks guys
post #7 of 17 Old 08-01-2011, 07:01 PM
biffgnar
biffgnar's Avatar
If you put the hi lift down under the axle where you put the bottle jack then maybe, maybe that would be sort of true. But with the height of the hi lift you end up having to jack from the frame or a bumper or a rocker and then you have to lift the whole suspension before axle lifts at all. End up having to lift everything so high that stability becomes a real issue. You don't want jeep falling off jack when you are working around it (assuming the handle doesn't brain you first).
biffgnar is offline
post #8 of 17 Old 08-01-2011, 09:13 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
Hmmm I never had a problem jacking any of my Jeeps with my Hi-Lift. Mine had been stable while lifting from bumpers I usually wrap chain around the frame and axle so you don't have to lift as high and the suspension doesn't cycle as much. I've also had to use one as a winch. I recommend one it is a good tool but a dangerous one
If you plan on getting one please watch these videos
http://www.youtube.com/user/hiliftjacks
'89 YJ The Smurf Build Thread
'99 XJ Black Betty Build Thread
Tom95YJ is offline
post #9 of 17 Old 08-01-2011, 10:01 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
You could have a 10" lift and 35", really almost 37" tires. and your factory jack would still work just fine for tire changing duties.
Remember... you jack up the axle to lift the tire up off the ground and a 33" tire only raises the axle 1.5" higher than a factory size 30" tire. My factory jack works fine with my 35" tires and it actually has enough height left over to go the additional inch 37" tires would require.
My Hi-Lift has been relegated to a home for my backyard shed's resident black widow spider for years now. It's too heavy, I never needed it, and it's too dangerous to be considered anything but a tool of last resort. I'd never consider using one on the trail until all other options are exausted. In 15 years of wheeling, I've only used my Hi-Lift twice... once just to try it out and once to change an axle shaft which was a dangerous way to do it. I would have been safer and completed the job faster using my bottle jack.
Getting Savvy...
Jerry Bransford is online now
post #10 of 17 Old 08-01-2011, 10:01 PM
billb2011
Way back in olden times cars used to come from the factory with high lifts in their spare tire kit....they were called "bumper jacks", they went to bottle and screws because bumper jacks were dangerous.
billb2011 is offline
post #11 of 17 Old 08-02-2011, 10:18 AM
thejafe
thejafe's Avatar
Agreed. Mine's been sitting in the garage for the last few years. in eight years of four-wheeling I've used mine exactly twice and really only seen others have to use them a handful of times. If anyone in your group is properly equipped with winches and recovery straps that should really be all you need in most situations.
thejafe is offline
post #12 of 17 Old 08-02-2011, 02:00 PM
Ross
I have used a Hi lift a few times for recovery. A couple times in conjunction with my winch. One of the hardest recoveries I did was a Suzuki Samaria. We needed the Hi lift, a winch and lots of rocks.
Another use I had for my Hi Lift was to hold my rocker guards in place while I mounted them. Made that job very easy.
I really donít like to use it, but I like to have it just in case.
01 TJ, 34 Super Swaper 34x10.5 bias, Winch, locked, belly up, some armor.
Ross is offline
post #13 of 17 Old 08-02-2011, 08:39 PM
Bigbob
Bigbob's Avatar
LOL I'll answer your question I guess.
If you want a high lift, get a high lift. I'd stay away from the knock offs. A high lift is a great tool, don't let anyone tell you different. It can be dangerous if you allow yourself to be dummer than the jack. Be smart and it will be a great investment that can last for a long time. I am 59 years old and bought my first High Lift when I was 23 and I just got my second one 5 years ago. The $75 is well spent.
Tractor Supply sells them pretty cheap now and then. If you buy one online then look for a place with free or at least cheap shipping as they are heavy.
Don't expect the High Lift to be your only jack or the best jack to use all the time. On a relative level surface the bottle type jack is indeed the unit to use as it's faster. Add mud, sticker patches, loose rock and the High Lift, used properly, is a wonderful tool. Just be smarter than the jack. And keep it oiled.
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is offline
post #14 of 17 Old 08-03-2011, 10:45 AM
'92 vegas YJ
R.I.P. Ratmonkey
'92 vegas YJ's Avatar
I use my hi-lift quite often. Usually someone in my group(usually me) gets stuck on some rocks that they just can't get off of. I use the lift to help raise it off the rock so they can either drive off or get winched off without tearing things to shreds.
I use EXTREME caution while using it and the only person within the vicinity of it is the one person jacking it. Everytime I go up one notch I stand far back and wait to it to settle a little bit. Once I do get it to point I want it at for the recovery I move to the other side of the vehicle in case the jack wants to bomb and/or projectile.
It has served its purpose for me.
~'92 YJ with many upgrades and many more calling my name..... it never ends
~'07.5 Dodge Ram Megacab 2500, 6.7L Cummins turbo diesel
April 2012, May 2013, May 2014 YJ of the month
'92 vegas YJ is offline
post #15 of 17 Old 08-03-2011, 01:02 PM
unrealtrip
Wow... FUD with regard to Hi-Lift jacks? LOLOL I step away from the online Jeep community for a couple years and everyone turns into a bunch of big babies.
Just get one, it will save your bacon many times over and they serve as many purposes as duct tape.
As for the one you linked, why not just get a real one for the same price? http://www.4wheelparts.com/Winches-a...8394&t_pl=9617
"Aut viam inveniam aut faciam" - I will either find a way or I will make one.
1995 YJ, SOA, D44/60, 35"s
2008 Dodge Ram SLT 4x4
www.secretreality.com
unrealtrip is offline
