Quantcast Help Testing Warn xd9000 motor - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > General Jeep & Off-Road Equipment > Help Testing Warn xd9000 motor
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire CarrierTruck-Lite's New LED Headlamp Series
Old 08-20-2009, 06:13 PM   #1
black71gp
I picked up a used xd9000 the other day, they guy said it wasnt working so got a deal i think on it.. trying to bypass the solenoids like Warn reccomends and I get nothing in either direction for the motor, when i touch the terminals it is acting like a dead short.
Between F1 and F2 I have 0 ohms, Between A and Ground 0 Ohms, and Between F1/F2 and A it is open.
I think i am going to take it into a starter shop in the morning and see whats up.. But is there anything else I can test? I had to replace two of the connection lugs for F1 and F2 they were stripped out. I took the motor apart and cleaned everything up, everything was really clean looked good and spun freely. I am just looking for some more motor tests please....
thanks
jarrod
black71gp is offline   Reply With Quote
Old 08-20-2009, 06:22 PM   #2
black71gp
ok well i messed with it a little more.. It seems to run then it just slowly slows down, I have it in freespool. it slows down and the connections get red hot... I am guessing something in the motor is bad.. magnets/ armature.. something like that... any idea where you can buy any of these pieces???
Old 08-20-2009, 07:52 PM   #3
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Might check eBay for a new motor.. I've seen them for less than $150. I paid $99 for the motor on my old M10000.
http://cgi.ebay.com/ebaymotors/NEW-12V-Warn-Winch-Motor-20-Spline-HEAVY-DUTY-AMT0406_W0QQcmdZViewItemQQ_trksidZp3286Q2ec0Q2em14 QQhashZitem5ad2ca752eQQitemZ390083540270QQptZLHQ5f DefaultDomainQ5f100
'80 CJ5 w/AMC360, T176, D44 w/Detroit 3.73s, RE 4" YJ lift and 35s..
Ground Pounder Fab
Lower 2
Guardrail
Down Schoolbus
Slickrock Tellico
Save
Crozet
More Crozet
BESRK is offline   Reply With Quote
Old 08-21-2009, 09:10 PM   #4
black71gp
thanks for the link.. starter shop said they got it working great.. $60 bucks.. so $460 for a xd9000... not bad goign to rebuild the other end with new grease and seals just to be safe.. but still i guess it was a lot dirtier inside than i thought it was.. they spent a while cleaning and testing so should be good to go now
Glock Forum
