Help with my Jeep - JeepForum.com
post #1 of 15 Old 10-18-2013, 07:33 PM Thread Starter
XJoffroad757
Help with my Jeep
Ok so i bought a 2000 jeep cherokee. When i looked up the VIN it says the vehicle is a 2000 jeep cherokee sport 2.5L , 4 cyl, 5 speed. The problem is; that the jeep is a 4 door, 4.0 v6, automatic. It also does not have a 4WD handle, it is 4x4 but has no 4WD option. Im wondering if the guy who owned it took it out when he swapped the engine..or? Ive also seen that where the fog light switch should be is a door unlock/lock switch. Im so confused i'm not sure what to think .
XJoffroad757 is offline
post #2 of 15 Old 10-18-2013, 11:43 PM
uberxj92
1992 XJ Cherokee
Sounds like it might have been wrecked bad. And fixed.
You said it is a 4x4 but, it doesn't have the shifter next to the transmission shifter?
Does it have a 4x4 front axle? Or straight pipe axle like a trailer?
2.5 to 4.0 inline 6 is a popular conversion.
And I am confused about the switch .
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline
post #3 of 15 Old 10-19-2013, 08:23 AM Thread Starter
XJoffroad757
Yes correct , it does not have the shifter next to the transmission shifter. I am currently ordering another carfax to find out. And it has a 4x4 front axle. And the switch confuses the hell out of me. Im not sure why he would put a door lock/unlock where the fog light switch would be
post #4 of 15 Old 10-19-2013, 03:13 PM
uberxj92
1992 XJ Cherokee
Ok look under the jeep see if there is a transfer case on the back of the Tranny.
This may be a project that they didn't finish.
Check the doors for vin numbers see if the match the dash.
The switch may be aftermarket locks or there was a bad wire that they just put in a switch to bypass
uberxj92 is offline
post #5 of 15 Old 10-19-2013, 03:15 PM
uberxj92
1992 XJ Cherokee
You said the Vin indicated a 2.5 liter. Make sure that both axles have the same gear ratios.
uberxj92 is offline
post #6 of 15 Old 10-19-2013, 03:29 PM Thread Starter
XJoffroad757
How would i go about that, i'm fairly new to jeeps.
post #7 of 15 Old 10-19-2013, 06:01 PM
GilaMtnJeep
GilaMtnJeep's Avatar
Put each axle on jack stands, make a mark on the driveshaft, and count the number of turns to get one revolution of the axle. About three DS revs equals, 3.07:1, 3-3/4 equals 3.73:1, just over four equals 4.10:1,and so on. Both axles need to be the same
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
post #8 of 15 Old 10-19-2013, 06:05 PM
uberxj92
1992 XJ Cherokee
I brought up the gearing cause if it was 2.5 then it should be 4.10. Seeing in how we are dealing with a project u want the op to be safe
uberxj92 is offline
post #9 of 15 Old 10-20-2013, 07:40 AM Thread Starter
XJoffroad757
So i found what i believe is the transfer case im sure its not hard to miss so i venture to thats what it is. In that case what would i have to do to make the handle or connect everything
post #10 of 15 Old 10-20-2013, 11:13 AM
GilaMtnJeep
Junk yard. You could find pretty much all the linkage, brackets, handle, etc. on a donor vehicle.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
post #11 of 15 Old 10-20-2013, 03:43 PM
uberxj92
1992 XJ Cherokee
You'll also need the center console too. Try to take notes and pics before you take the linkages out of donor. It'll help you on install.
Anything we can do we will to help. Where do you live?
uberxj92 is offline
post #12 of 15 Old 10-20-2013, 07:23 PM Thread Starter
XJoffroad757
I live in virginia beach. Ok i found out i do not have the things that connect in the front to make it 4WD so it has a transfer case but is only 2wd
post #13 of 15 Old 10-20-2013, 10:13 PM
uberxj92
1992 XJ Cherokee
Ok you'll need the console from a 4wd,the linkage, front driveshaft.
uberxj92 is offline
post #14 of 15 Old 10-21-2013, 08:12 AM Thread Starter
XJoffroad757
And i can find these at a DIY junkyard?
post #15 of 15 Old 10-21-2013, 04:38 PM
uberxj92
1992 XJ Cherokee
Should be able to. We have several of them here can find those parts all day
uberxj92 is offline
